Old 09-28-2021, 05:17 PM   #1
2022 25' International
Eagle , Colorado
Propane Extension Hose for Generator
I have been having an incredibly difficult time finding a propane extension cord/hose (3-5 feet or so) that I can use with my propane generator so that I donít have to remove the shell around the tanks. Attached is what should normally connect to the tank (and it works fine when I do so). But Iím looking for a hose that would connect from the tank to this piece that goes to the generator. In short, Iím just trying to extend the normal tank connection by 3-5 feet.
Amazon is turning up a huge number of different pieces and Ace Hardware hasnít been sufficiently helpful.
Also, I should note that Iíve connected it via the quick connect valve on the tongue but unfortunately it doesnít put out enough volume of LPG and the generator just sputters. If anyone has a fix for that, Iím all ears!
Thank you in advance!!
jmslade is offline   Reply With Quote
Old 09-28-2021, 06:01 PM   #2
1997 28' Excella
Daniels , West Virginia
Nova Rubber Co Inc.
Custom hose mfg. WV. Long way from you but I’ll bet UPS can get it to you. Quality company/quality work
rich e is offline   Reply With Quote
Old 09-28-2021, 06:23 PM   #3
Eagle , Colorado
Thanks. I can’t be the first person who has wanted to simply extend the location of their tank connection. I have to believe there’s a hose out there and I’m just looking at the wrong things. (I mean, as much as I want to believe that I always search for the right things.)
Old 09-29-2021, 05:59 AM   #4
1997 28' Excella
I stumbled onto this. CAMCO fc 16002. ???
Old 09-29-2021, 07:27 AM   #5
2019 25' Flying Cloud
Houston , Texas
Originally Posted by jmslade View Post
Also, I should note that I’ve connected it via the quick connect valve on the tongue but unfortunately it doesn’t put out enough volume of LPG and the generator just sputters. If anyone has a fix for that, I’m all ears!
You would need to change the quick connect fitting to a larger size. This is from the FAQ on Genconnex's website:
"Can I run two EU2200i’s at the same time from my camper’s 1/4” propane quick disconnect?Yes, if the connector is only a few feet from the tank and if you are just using the two to start a 12,000 or 14,000 BTU A/C unit that normally run at approximately 1600 Watts once started. No, if you want to run both generators in total above this power for any length of time or have your 1/4” quick disconnect more than a few feet away. In this case you should have your line upgraded to 3/8” i.d. with a 3/8” quick disconnect installed and or use our 12’ x ⅜” dual output hose with our ľ” to ⅜” adapter."
DCPAS is offline   Reply With Quote
Old 09-29-2021, 09:20 AM   #6
SilverFire
2007 19' Bambi
EUGENE , OR
Hutch Mountain
[URL="http://https://www.hutchmountain.com/"]
They'll make up whatever you need, quality propane hoses.
Regards SilverFire
SilverFire is offline   Reply With Quote
Old 09-29-2021, 09:36 AM   #7
2017 27' Flying Cloud
Fernandina Beach , FL
Hutch Mountain
Originally Posted by SilverFire View Post
Hutch Mountain
Regards SilverFire
I second the recommendation to contact Hutchmountain.
I have their extension hose, with adapters, to connect to the LPG port on the trailer tongue, together with the appropriate regulator. Our Honda eu2200i works great with this set up.
Bob Peahl is offline   Reply With Quote
Old 09-29-2021, 09:48 AM   #8
Jugadorone's Avatar
2019 30' Flying Cloud
Lucedale , Mississippi
This is what i was sent from Champion for my Dual fuel 3400.
Unfortunately we do not sell an extension kit. Below is a link of the part required to extend you LPG hose.
Here is a link to the parts required on amazon https://www.amazon.com/hz/wishlist/ls/TXNB1SWETOFC
THE GENERATOR REQUIRES Ĺ PSI AND A FLOW RATE UP TO 76,000 BTU/HR WHEN UNDER FULL LOAD.
Jugadorone is offline   Reply With Quote
Old 09-29-2021, 10:08 AM   #9
SailorSam205's Avatar
South East , Michigan
Another possible site to get what you need is https://propanegear.com/promo/. The front page has a banner that says "We build custom hoses Fittings, lengths, multiples.. you name it, we make it".
I bought some fittings and hose for my Blackstone from them. Best price I could find at the time and 2 years on, still in good shape.
Al
2017 29' SOB, 2019 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 09-29-2021, 10:14 AM   #10
2014 27' FB International
Hooper , Utah
Go in line and search for a "Rubber & Hose Supply" store. They all make up a proper hose size/length and the correct hose connections. They make up all type of hoses for different kinds of uses. I have purchased hoses for propane, tractor hydraulic hose, etc
It is not a difficult issue......just stay away from the big box stores like ACE, Home Depot, RV stores, etc.
albret is offline   Reply With Quote
Old 09-29-2021, 11:34 AM   #11
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
JM, will the grill hose extension work? I've got one that works for my Onan 2500 set.
Name:	Screenshot_20210929-122640_Amazon Shopping.jpg
Streamracer is offline   Reply With Quote
Old 09-29-2021, 01:07 PM   #12
2021 27' Globetrotter
Malibu , California
Go to Loweís, in the BBQ department they sell extension hoses where the regulator is not anywhere close to where youíll attach to the main tanks, and it works exactly how you want it. I think it was $21.
CMHM is offline   Reply With Quote
Old 09-29-2021, 01:51 PM   #13
Images: 59
I'll second this idea. I used an old BBQ hose that came with my now abandoned grill.
Old 09-29-2021, 01:53 PM   #14
Eagle , Colorado
I think that would be perfect! Iím now intrigued about upgrading my quick connect, though, to see if I can just run it all through there. But if thatís going to take any significant work, Iím going to order what you sent!
Old 09-29-2021, 08:51 PM   #15
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I run a 6,300 Yamaha generator on a tongue quick disconnect. I bought a HD Marshal-Mercator (Merc) automatic changeover and replaced the OEM regulator (nonHD). No volume problems now. If you look at the specs you will see the overall size is the same, but the regulator is designed to handle much higher outputs, especially during change over when the selector has not been switched to the full tank, but changeover has occurred.
guskmg
LPG Extension Hose Help Blighcapn LP Gas, Piping, Tanks & Regulators 3 10-07-2020 05:59 AM
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 10:41 AM
Black Flush Extension Hose philipsinewe Waste Systems, Tanks & Totes 13 11-02-2015 12:09 PM
Sewer Solution 10' extension hose. Will_Brule Waste Systems, Tanks & Totes 1 09-07-2013 04:55 PM
