Originally Posted by 2travelers
Original propane detector failed within one year. Replacement has also failed within a year.
Third detector won't power up. Checked voltage and got 8.5 volts.
Connected failed unit and it fails to power up als
All connections were wire to wire.
Any thoughts?
I think you found your issue. Find the appropriate fuse in the panel and check voltage there. Check the screw terminals at the fuse panel for tightness. Find the 12v ground bar and check all of the connections there. Trace as much of the wire as possible looking for problems.
There are counterfeit LP detectors on the market, Although not of your model, its still possible some like yours were also counterfeit. Personally, I would look for the voltage problem and also consider replacing the unit with a MTI unit
Charles
'03 Ram 2500 CTD, 5.9L HO PacBrake six speed std cab long bed Leer top and 2008 BigfootRV 21RB trailer.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
