RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-21-2018, 09:03 PM   #21
1966 22' Safari
Fredericksburg , Texas
Originally Posted by Dingo Girl View Post
I have a really nice flare tool that I bought years ago to do some work in my home. No leaks.
bought all new shut offs and flare nuts. The Ts that were originally used will be used again. They are still in perfect condition.
I will do some practice flares & bends before starting . Better safe than sorry.
Just wondering, double flares? Bubba
Bubba L is online now   Reply With Quote
Old 08-22-2018, 03:14 PM   #22
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The plan as of right now is to do single flares.
It is what was there originally and they lasted for decades.
Dingo Girl is offline   Reply With Quote
Old 08-31-2018, 10:33 PM   #23
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I have the cushion clips.
Should I attach them to the underside with rivets or with stainless sheet metal screws?
Thank you.
Old 09-01-2018, 01:16 AM   #24
2007 22' International CCD
Propane Copper Pipe Hangers
I would use stainless steel screws and an internal tooth lock washer just to be safer from vibration. I like to be able to easily fix stuff. If you routinely carry an electric drill, bits, and a pop rivet tool, have at it with wide head pop rivets.
Your repair habits rule the correct answer. Admittedly I carry the drill and all the other stuff as well. Just don’t like to drill out rivets over my face while lying under the AS.
rmkrum is online now   Reply With Quote
Old 09-01-2018, 06:51 AM   #25
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I like the idea of screws and lock washers. Thank you.
I don't much care for drilling things out over my face either.
Drilling for the new belly pan into the new crossmembers and outriggers was unpleasant at best.
Old 09-01-2018, 10:31 AM   #26
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Yeah, the burning hot chips of metal falling down on face and body aren’t pleasant....
I used black pipe for my long run under the trailer and then branched with copper....
My next project will use something like this..... Click image for larger version
Old 09-01-2018, 04:00 PM   #27
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I dress like a bee keeper when I drill under the trailer. Those chips always find a way in though. They only seem to find the most tender skin too.
My long run is only about 7 feet to the first branch. I'm using copper.
Propane: Black pipe or Copper under trailer? Tony S LP Gas, Piping, Tanks & Regulators 16 06-04-2015 03:19 PM
LP Wierdness / Where to buy copper LP pipe and fittings? nickglase LP Gas, Piping, Tanks & Regulators 19 03-11-2006 04:43 PM
Copper pipe help Crazyland Fresh Water Systems 26 03-03-2005 07:04 PM
Need HELP! Access to the copper pipe. Crazyland Plumbing - Systems & Fixtures 6 08-13-2004 04:15 PM
1950s copper pipe connections ivesterm Plumbing - Systems & Fixtures 9 10-02-2003 06:58 AM
