RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-17-2020, 08:01 AM   #1
Park City , Utah
Possible regulator issue or leak?
We arrived at our campsite last night. When I opened the cover of the LP tanks I smelled a little bit of LP. We had been driving in 95 degree heat for >5 hours, so I figured a bit of LP may have escaped.
I checked the valves and connections and they all seemed fine, so I went ahead and opened one of the valves. Stove wouldnít turn on, either with the built in igniter or a lighter, and we didnít smell any LP.
I turned off both valves, then disconnected and bled them. I noticed then that the regulator was still showing green, and this was true in both positions (left and right). I tapped it a few times but didnít help.
Then I reconnected one valve and slowly turned it on. The stove worked.
So, we now have LP but Iím worried about a potential safety issue and it seems the regulator isnít working? What would you suggest?
switters is offline   Reply With Quote
Old 09-17-2020, 08:55 AM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
If you opened the valves too quickly, the overflow protection system probably stopped the flow. Valves must be opened slowly!! With the heat, and if tanks were full, the relief valve might have opened to bleed off excess pressure, causing the odor. Keep an eye on the system, but nothing sounds like a major problem.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 09-20-2020, 09:34 PM   #3
Park City , Utah
Thanks, everyone. The propane worked just fine for the entire trip so I think you were right that I just opened it too quickly and/or the heat caused leakage.
Old 09-20-2020, 10:53 PM   #4
2018 25' International
Slidell , Louisiana
It is as was surmised the temperature change triggered the high outlet pressure protection mechanism and gas bled out causing the odor you detected. It also triggered the shut off mechanism which is why the system did not work until you bled it out and started over. All is well, false alarm. It happens sometimes.
Possible Inverter Issue Lag323 Batteries, Univolts, Converters & Inverters 15 04-16-2019 11:37 AM
'67 Overlander - Toilet Bolt Pattern issue! 5&11 to 3&9 o'clock conversion possible? Billyjchase Sinks, Showers & Toilets 0 11-12-2017 05:49 PM
URGENT SAFETY ISSUE - Sturgis Regulator Recall khollister LP Gas, Piping, Tanks & Regulators 41 07-09-2016 06:59 AM
Odd Regulator Issue kamadeca LP Gas, Piping, Tanks & Regulators 4 06-16-2014 12:27 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 11:52 AM
