RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-19-2018, 01:39 PM   #1
wmb
2013 25' Flying Cloud
PEX in the propane line?
I just noticed this while I was investigating a fresh water leak dripping down from the front of the wheel well on the drivers side.
The propane lines that run from the tanks up front, underneath the trailer, are all copper except for a short length that splits off the main pipe running across from the passenger side. There's a copper run off the end of that main that feeds the fridge, but there's a T-split section that also runs up in front of wheel well that's white PVC. I crawled underneath to read the markings and it says "pex potable water 100psi". As I was investigating the city water inlet inside the trailer behind the bathroom sink I can see copper pipe running along the top of the wheel well, and I think this must feed the water heater.
The original owners of this trailer kept impeccable service records and there's nothing in there about replacing any propane lines, so could this really have been done at the factory?
wmb is offline   Reply With Quote
Old 12-19-2018, 02:19 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Is it possible that the copper line is inside the pex?
Richard
Old 12-19-2018, 02:44 PM   #3
wmb
I hadn't considered that, but I guess it's entirely possible. What would be the reason for doing that on just one small section, though? I'll get a picture of the one end I can see (at the T-joint) - the other end disappears into the underside of the trailer and can't see how it connects to the copper inside.
Old 12-19-2018, 02:48 PM   #4
2007 22' International CCD
Some installers run copper propane lines inside PEX to protect from flying debris, etc. The inconsistency of that practice is not unusual...
I'd be checking carefully to see if some previous owner didn't actually USE PEX for propane service...and fix it quick if that is what you have.
rmkrum is online now   Reply With Quote
Old 12-19-2018, 03:39 PM   #5
wmb
Yes, I think you're right. I was able to get far enough under to get a good look a the T-joint and the PEX is just acting as a wrapper for the copper. Thanks!
Old 12-19-2018, 03:50 PM   #6
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Yes, mine came from the factory with some of the propane line sections run inside PEX. It even got painted the "hitch gray" on the front of the trailer.
thewarden is offline   Reply With Quote
Old 12-19-2018, 04:12 PM   #7
The PEX is a convenient way to protect the tubing against damage--wish mine was like that. We've collected a few dings and scrapes in the copper...
Old 12-19-2018, 05:19 PM   #8
wmb
Yep - makes perfect sense to me now that I think about it. I think I was thrown by the fact that it was just this one small run, and the "potable water" markings...
Old 12-19-2018, 05:59 PM   #9
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
just spitballing here but would that create a rub over time and a leak.. Its used in gas lines being installed into masonry fireplaces to protect the line some copper some black iron pipe. its called a sleeve in that instance.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 12-19-2018, 07:47 PM   #10
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
I may be wrong, but I thought I read here on the forum that using a sleeve on the propane lines is required for trailers going to Canada.
bweybright is offline   Reply With Quote
Old 12-19-2018, 10:21 PM   #11
PEX is not as hard or sharp as the copper. Sleeves over the copper is a good idea anywhere
Old 12-19-2018, 10:46 PM   #12
I would and do agree. But is there a standard on color internationally similar to wire that would help clarify what one should do if they want to sleeve propane lines?
This is totally foreign territory to me, but does have me interested as I see value to the concept.
Old 12-19-2018, 10:56 PM   #13
Iím not aware of a standard, but red or yellow sleeve would be my choice.
Natural gas lines are usually yellow or orange for visibility when digging.
Old 12-20-2018, 10:17 AM   #14
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
Originally Posted by rmkrum View Post
I’m not aware of a standard, but red or yellow sleeve would be my choice.
I like your yellow color idea, but the standard only says: "5.3.8.3 Tubing or hose shall be routed to be protected from physical damage, sharp edges, and moving parts." [NFPA 1192-2018, Standard on Recreational Vehicles] NFPA provides free access to this standard.
Am glad Airstream provided some protection.
For those of us upgrading, renovating, and maintaining, another important safety item on propane tubing or hose locations: "5.3.8.1 Tubing or hose shall not be run inside walls, floors, partitions, or ceilings."
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 12-20-2018, 10:19 AM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We covered all the copper propane lines with the flex wiring cover used to cover the wire bundles in vehicles to protect from road trash.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 12-20-2018, 11:52 AM   #16
2019 27' Globetrotter
Denver , North Carolina
Sounds like a great idea that would be easy to do. I'll keep an eye on my propane lines for road rash. Thx
link2dks is offline   Reply With Quote
Pex or not to Pex? Isuzusweet Fresh Water Systems 32 09-15-2019 12:21 AM
Pex or not to Pex ? Thomasmg Fresh Water Systems 28 03-19-2016 04:05 PM
To PEX or not To PEX perryg114 Sinks, Showers & Toilets 69 10-04-2012 05:32 PM
