Old 06-29-2020, 06:19 PM   #1
Billyjchase's Avatar
1967 26' Overlander
Eugene , Oregon
Send a message via Skype™ to Billyjchase
PEX + '68 Overlander Hot Water Heater Piping Conversion Problem
Dear Forum,
My "plan" is to bring in a PEX hot water line from our house and via sharkbite fittings and shut off/on valves, be able to connect to our homes hot water line while beached at home and disconnect/revert to the AS's hot water heater when traveling. (Hopefully the diagram pic makes sense).
Issue -
- The original copper lines are not .62" OD (PEX 1/2" Di) but instead the copper lines are a smaller .049" OD.
- Im not a plumber (although I play one on TV with SharkBite and PEX lol)
Solutions?
- Does Sharkbite (or similar company) make a fitting that I can replace the thread-on connectors into the hot water tank, that accept a standard 1/2" PEX tubing?
I have plenty of other pics and inner diameter readings if needed.
Im open to sweat welding different diameter copper pipe if its the only option to get me to stanard 1/2" diameter piping... and is even possible. But hoping for solution with less flames involved!J
Any other options anyone can suggest?
Thanks!
Billy J. Chase
Name:	1 - Hot Water Tank Line Diagram.jpg
ID:	371539   Click image for larger version
Name:	2 - Outer DI - Hot and Cold Water Lines - Hot Water Tank.jpg
Name:	3 - 1.5in PEX Tubing - Outer DI.jpg
ID:	371541   Click image for larger version
Name:	4- Water Line Connection - Hot Water Heater.jpg
Warm Regards,
Billy & Stephie Jo Chase
"The Granny Jo Airstream"
grannyjoairstream@gmail.com
Billyjchase is offline   Reply With Quote
Connecting home hot water line to '67 Overlander hot water line w/PEX~Sharkbite Billyjchase Plumbing - Systems & Fixtures 4 06-29-2020 10:00 PM
polybutylene and pex piping Dan Barker Plumbing - Systems & Fixtures 9 05-26-2020 10:34 PM
Hot Water Heater Works But No Hot Water Althea Water Heaters, Filters & Pumps 6 04-16-2016 10:45 AM
To PEX or not To PEX perryg114 Sinks, Showers & Toilets 69 10-04-2012 05:32 PM
Hot water piping Pahaska 2002 - 2005 International 8 01-29-2003 08:19 AM
