06-15-2021, 01:05 PM
2016 30' Classic
Indianapolis
, Indiana
Perfect grate for Dometic gas stove
I replaced the silly wire frames that surrounded the gas burners on our Dometic stove. This two-piece grate designed for a Furion stove fit and function perfectly.
Did not drill the stove pan because the grates fit well and do not move around.
We no longer have pans tilt off the burner. And can slide them around at will.
Very happy with the choice.
E-Trailer.com
Die-Cast Grate for Furrion Range Cooktop - 2 Piece
Item # CFSRE21SA002. $193
2016 GMC Sierra 2500 HD
2016 30' Classic
ProPride Hitch
Voyager back-up camera
10-25-2022, 11:16 AM
2024 23' International
Seattle
This is JUST what I have been looking for!
E-Trailer.com
Thank you for posting, I did a google search, and this post was the first on the list!
Question(s): I see you removed those silly wire frames on each burner. How difficult was it to do that? Did you have to make any other modifications? The lid closes perfectly? How does it hold up while traveling?
THANK YOU!!
BogeyPro
Seattle, Wa
2024 International 23' Twin
2021 Ford F-150 XLT 4x2 Powerboost
10-25-2022, 12:14 PM
2019 27' Globetrotter
McHenry
Not to step on David but I can answer your question. The wire grates just pull out of the grommets.
Our cast grates have held up fine since January of 2021. I did cut some rubber tubing (think auto vacuum tubing) to act as bumpers for the grates to keep them from moving around. They make it a snug fit. YMMV
No problems with heat on the tubing - they’re far away from the flame. It’s so much nicer to cook on; you don’t need to keep one hand on the handle.
Good luck!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
10-26-2022, 10:08 AM
Seattle
thank you, Jeff, for the response and the great information and pictures!!
BogeyPro
Seattle, Wa
10-27-2022, 03:58 PM
2018 30' Classic
New Park
, Pennsylvania
I have this exact same grate from eTrailer…Love it. It feels much safer when I am cooking.
The first grate needs pulled out, rotated 180 degrees. It will line up over the front burner better.
Just saying…
What if...we got it right this time?
Tanner the tin tube
10-27-2022, 04:49 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
I've also replaced the original burner grates with the Furrion grates from etrailer. Much better ......and safer!
04-16-2023, 12:41 PM
Missouri Valley
, Iowa
I made the switch to the Furrion grates just today!! They fit a bit snug so I ground off the ends of both grates. Now, they fit in easily. A big thanks to whoever was the first to report on this improvement!! Also, a big thanks to those that gave info and part numbers for the metal plugs from McMaster-Carr to fill the holes on stove top and the silicone caps from Mocap to protect the grate feet.
Dan
04-17-2023, 01:27 PM
Seattle
More Information Request
Dan
Hey, Farmer Dan. What kind of tool did you use to "grind off the ends of both grates"? I'm assuming a high speed grinder that I would have to rent at Home Depot...so then what kind of brush on the grinder did you use?
Also, I looked back on this thread...could not find anything on the "silicon caps from Mocap" to protect the grate feet. Could you elaborate?
Much appreciated! I also have these grates and they are a huge improvement.
BogeyPro
BogeyPro
Seattle, Wa
04-17-2023, 05:53 PM
Missouri Valley
, Iowa
I just used my bench mounted grinder with the tool rest. Keep a firm grip and the grate on the rest to avoid unexpected movement. I think cast iron can be a bit touchy to grind on so go slowly. I didn't brush after grinding. From McMaster-Carr I got nickel-plated metal plugs to go in the stove-top holes where grill / grommets were. 1/4" diameter snap in. Part # 9563K41. Pack of 50. With shipping $26.60. For the peg-legs of the grates from Mocap I used part #MEC.148-1. These are black silicone caps. They are 1" long. Trim them to length to fit. $20.66 for 50. Don't remember shipping cost. These make everything work pretty well.
Dan
06-20-2023, 01:56 PM
Scout
2019 28' Flying Cloud
Livingston
, Happy Camper, USA
This is great, however, I have a different cooktop, with a folding aluminum cover. The measurements are larger than the grates that I have currently, so I'm fairly certain this won't work for me. Anyone else have the Dometic CA-35 series cooktop?
10-31-2023, 01:28 PM
2019 25' Flying Cloud
Westmoreland
, New Hampshire
We also have a 2019 with the same cooktop you have. I ordered the Furion grates but they did not fit and I had to send them back. Did you find any that did fit?
01-23-2024, 06:46 AM
2008 27' International FB
Petaluma
I have an old Amana stove in my 2008 27FB. I bought the Furion grates on the classifieds and they fit fine. i drilled some holes in the stovetop to "hold" the leg pins cast into the grates so they don't move around. I'll report back after some use. i did have to bend the fingers hanging down on the folding cooktop travel cover to let it clear the new grates but they were easily manipulated with my hands/thumbs. Before and after picture.
Looking for adventure in whatever comes our way.
- Brad
01-24-2024, 07:40 AM
hang up and drive
2010 30' Classic
Carlisle
, Pennsylvania
Exactly what I was wondering as our 2010 has the same stove.
Thanks!
Kyle
2023 Ford F350 Lariat 7.3/4.30 FX4 CCLB
2010 Classic Limited 30
ProPride P3-1400
01-24-2024, 10:48 AM
Tampa
I love the "finished" look.
But, let me ask, if you reversed the front half wouldn't the grate opening more align with the front burner?
01-25-2024, 06:33 AM
2023 27' Globetrotter
Florence
, Kentucky
Greetings,
We've also purchased these grates on etrailer and pulled off the original wire racks on the dometic stove in our 2023 27FBT GT. They slid right in with no need to grind anything off.
We're still wondering how anyone could keep a pot from falling off those wire racks and why Dometic thinks its a good idea..cheaper I suppose.. yes the front grate needs to turn 180 from the picture shown and the grates will not line up perfect but they're close enough and provide a much needed secure surface to cook on. My wife loves to cook (lucky me) and the grates give you space to move a pot off the burners to cool down or just to sit a hot pan somewhere.
Safe travels
