RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-11-2018, 11:58 AM   #41
2010 20' Flying Cloud
Clearwater , British Columbia
The 1500 chevy crewcab TV gets standard 87 octane gas, that may or may not have up to 10% ethanol here in BC. I notice seasonal variance in reported fuel economy, but given the price difference between 87 and 91 octane fuel, I have not tested if there is a difference between the ethanol additive or not.
For all my small engines - snowmobile, generators and all my small 2-stroke equipment, I put the ethanol-free 91 octane fuel into the jerrycan and add seafoam fuel stabilizer. I drain the tanks on the small 2-stokes when not in use for a month or more, and drain the carbs on the generators and top up the tanks. Never had a maintenance issue with any of my engines due to fuel issues. Friends that use 87 octane with 10% ethanol seem to have more engine issues with their sleds and chainsaws. The honda generators, as long as the carbs are emptied for storage, don't seem to care which octane or blend of gas is used.
BCMtnHound is offline   Reply With Quote
Old 04-12-2018, 03:45 PM   #42
1986 31' Sovereign
Miami , Florida
It was just on the Bloomberg feed that the President is pushing for a B15 mandate to help the agriculture segment.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 04-17-2018, 06:14 PM   #43
1999 28' Excella
Lake Mary , Florida
Non Ethanol for power & better mileage
I only use non-ethanol in all my boats and small engines and have never had problems with performance or carb jet clogs. I recently began feeding my Dodge 5.9L gasser with non-ethanol. Wound up getting 2 to 2.5 more miles per gallon and better uphill performance when pulling heavy trailers.
Basic physics, gas has more BTU/gallon than ethanol.
Oh, and have you ever wondered who checks to make sure the E10 pump has no more than 10%ethanol? You buy what they pump at the fuel depot, quality control is not on their checklist
suncoasteng is offline   Reply With Quote
Old 04-17-2018, 07:02 PM   #44
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Originally Posted by CRH View Post
On the other hand, I have been using ethanol fuel for years in my vehicles, power equipment, and boat with no trouble. My stuff is all old, too. I cut the gas valve off if they have it and run them dry. I drain the tanks on seasonal equipment.
Ethanol has been in gasoline since the early 1970’s....about the time the carburetor kits started using the viton tipped needle...
Old 04-17-2018, 08:29 PM   #45
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
E85=51-83%
Originally Posted by suncoasteng View Post
...Oh, and have you ever wondered who checks to make sure the E10 pump has no more than 10%ethanol?...
I was at the truck stop where I purchase my gasoline. I previously had a E-85 Flex Fuel vehicle and used the fuel. There on the pump was the ethanol handle in yellow, with the sign above the dispenser:
"ETHANOL FUEL ONLY-51%-83%"
When I asked inside why the ethanol-gasoline blend could be more than 15%, I was told the standard changed possibly due to more gas/electrics becoming available.
https://www.afdc.energy.gov/fuels/et...e85_specs.html
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Old 04-18-2018, 08:13 AM   #46
Little River , South Carolina
Have you tried pure gas in a motorcycle?
I had a Honda VTX1300 trike which I had only used gas/ethanol in because I didn't see pure gas offered. When I found pure gas I tried 87 octane pure gas and it made a HUGE difference in power and the smoothness of the engine IMMEDIATELY. I was hooked!
I own an E450 class C now which I would like to try pure gas in, but when you have to try to eek 10 MPG out of the V10, I'm not sure the 60 cents per gallon difference would be worth it.
roadyacht is offline   Reply With Quote
Old 04-18-2018, 08:59 AM   #47
1999 28' Excella
Lake Mary , Florida
Non Ethanol
Actually, it might be worth it. Where I live, 90 octane non ethanol gas is only 40cents per gallon more - about 15% more than 87 octane E-10.
If your 10mpg RV or TV goes up to 11.5mpg and you gain engine power, your credit card will never see a difference at the pump.
I also noticed my exhaust quit dripping lots of water since I stopped using e--10
Old 04-18-2018, 09:00 AM   #48
r carl's Avatar
Lin , Ne
I have never seen it more than 25 cents more here.
Old 04-18-2018, 11:17 AM   #49
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I spent a year and a half alternating, one month each, between " clear gas" and gas with "corn syrup". I kept track of every mile and every gallon. For my Toyota T100 with a 3.4 six cylinder engine the "magic number" is 16%. I averaged 16% better mileage through differing seasons and conditions. So....... when the cost difference between the clear gas and that with corn syrup is 16% or less I use the clear gas.
I quit guessing and did the math.
Sam
samb is offline   Reply With Quote
Old 04-18-2018, 12:06 PM   #50
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
We have an ethanol free station one mile away. Consequently or not we're use it in my Suburban 8.1 and princesses, (this dictation thing is really cool) continuing. In the deer wipes GOK 350 MBA. Haven't really noticed any difference and the mileages I neither one of the vehicles.
On a trip to New Bedford Massachusetts relentlessly with the suburban had the opportunity to use both E free into your gasoline. Not tooling, we got 12.9 and 13.2 res respective Lee, you can figure out which is which. Either way it didn't really make much difference. I guess I'm just no school but I prefer to use the eastern all free pretzel in all my Gossling Power equipment.
This was factual early oh very fun post.... Send hosiery. 👍😂
“It’s not the system thats the problem, think Circus, it’s not the car, it’s that the car is full of Clowns.”
John Turley
Tahawus
Old 04-19-2018, 10:24 AM   #51
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Great auto spell checker and word correction action....
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 04-19-2018, 10:34 AM   #52
dznf0g's Avatar
Oswego , Illinois
Dang, Robert....it was only a bit after noon when you posted. Gettin' into the grapes a bit early?
-Rich-
Old 04-19-2018, 01:44 PM   #53
Long Island , New York
. . . or maybe sniffing some ethanol . . . ?
Old 04-20-2018, 11:46 AM   #54
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I use both in. 72 ford pickup ,390, And in our Toyota Venza....no difference which gas we use..same story with the model A and modelT...no difference..
Ethanol gas used in Honda Eu2000i Tom Lafferty LP Gas, Piping, Tanks & Regulators 42 12-16-2015 02:43 PM
Non-Ethanol Gas Stations pappy19 On The Road... 27 03-23-2014 09:59 AM
The introduction of e15 ethanol bukib General Motorhome Topics 14 08-18-2011 01:23 PM
ethanol norbert Off Topic Forum 13 07-19-2005 07:42 AM
Wow! Something changed......! Pick On The Road... 14 04-14-2003 06:33 PM
