No Power to Propane Detector
Hello,
I have a 2013 International Signature 27FB.
A couple weeks ago my propane gas detector began chirping and displayed a yellow warning light. It had reached it's end of life after seven years of active use. I muted the chirping by depressing the reset button but it only worked for twelve hours and then started chirping again so I cut the wires as I had to send for a new detector and it wouldn't arrive for a couple of weeks.
I installed the new detector but the unit didn't get any power. I removed it and tested the old unit again and nothing. I'm assuming that I'm not getting any power in the wiring to the unit any longer.
I looked up some threads about this situation and found that there's a chance that there is an inline fuse that may have blown however I don't know where to look for it in my year and model.
Before I go nuts looking for it, does anyone out there know where it's located? I'm not a very technical person when it comes to this stuff so photos and a detailed description on where to find it would be great if you have them.
Or, if you have any other ideas of what could be causing the problem, please let me know.
Thank you in advance! John
