07-18-2022, 06:56 AM
2022 27' Globetrotter
Mullica Hill
, New Jersey
new couple question (propane line)
Hi everyone, new couple just getting started on the Airstream Life!!!
We have a 2022 GT27FBT and have a question regarding the propane line routing. i have included pictures, but the question is the proximity to the passenger side front stabilizer rotating element. Seems having the hose so close to rotation will damage it over time. TIA.
Ed and Liz
07-18-2022, 07:18 AM
1994 34' Excella
Warren
, Manitoba
I cover all the exposed propane lines with old garden hose. Split it lengthwise and slip over the lines. I have also seen the black plastic wire loom used for the same purpose.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
07-18-2022, 07:23 AM
1998 31' Excella 1000
1979 23' Safari
Mooresville
, Indiana
The copper line is soft you can bend it with your hands to get it out of the way.
Damon
#4827
07-18-2022, 08:15 AM
2008 22' Safari
Spicewood (W of Austin)
That rubber hose is inappropriate for that installation. A rigid line..preferrably copper…should be used…and routed away from the jack.
07-18-2022, 08:36 AM
Escape Pod II
2022 23' Flying Cloud
2018 22' Sport
Orange
The same guy that ran your line must have run mine too. I repositioned the line to run over the jack shaft. It was also hanging down at the A frame in the front.
JEWare
07-18-2022, 09:03 AM
2017 19' Flying Cloud
Calgary
, Alberta
This is interesting. On my 2017 Flying Cloud the underbody propane lines are copper covered in what looks like Pex.
07-18-2022, 09:28 AM
2021 16' Caravel
Fullerton
Ed and Liz,
My 2021 Caravel 16 had that propane line installed in the exact same manner, which makes NO SENSE. I unbolted and removed the stabilizer, tucked the line up under the frame and reinstalled the stabilizer. Now the line is not dangling loosely in harms way and better supported by the jack frame. Took all of five minutes.
FYI, put a jack under the tongue if you ever work under you trailer, just in case the tongue jack fails while you’re underneath, which would be bad.
Hope this helps.
07-18-2022, 09:37 AM
2021 27' Globetrotter
Sumterville
Bob, are the stabilizer bolts threaded into a fixed nut or do you need access to both ends to reinstall?
My stabilizer pinched that propane line early on.
Bill
07-18-2022, 11:24 AM
1994 34' Excella
Warren
, Manitoba
Reference to the comment made by Boxite, the garden hose is used to COVER the copper propane line, not replace it!! I live on gravel roads and the garden hose protects the copper line from rocks and other road debris. It is a good idea to wrap the copper lines with something to protect them, and old garden hose works great!!
ACI #7394
1994 Excella 34'
Hensley Hitch
07-18-2022, 07:54 PM
Mullica Hill
, New Jersey
Thanks everyone for your help. We communicated with dealer to make sure we don’t void any warranty coverage. Just want to make sure the correction is done once and done correctly.
07-18-2022, 08:11 PM
2021 30' Flying Cloud
Santa Monica
I have the same issue on my FC 30bunk and I’ve been wanting to fix it. I incorrectly assumed they must have had a reason for doing it that way. 2 questions:
1. Has anyone changed out the propane hose to something safer altogether? It’s made me nervous that the propane line is just hanging there and could catch on something. I
2. Probably a simple question, but does anyone have the part number to add more of the hooks to better secure the propane line and is there any issue with drilling into the belly pan (or is it the same process as drilling a hole in the roof and using sealant in the hole)?
Thanks.
07-18-2022, 09:27 PM
Escape Pod II
2018 22' Sport
Orange
You can get hold down clamps at hardware stores or places like Home Depot. I used self tapping screws to attach mine to the belly pan or to the frame. Sorry, I don't remember what the outside diameter of the propane hose is.
JEWare
07-27-2022, 04:44 PM
2021 16' Caravel
Fullerton
Bill
Bill,
Sorry for the delay. You've probably figured this out by now, but the bolts go into a threaded nut in the frame, i.e. you only need one socket wrench.
07-27-2022, 06:20 PM
Sumterville
Thanks for the response, Bob. I have been busy in other projects and have not pursued this yet.
Happy travels.
