Old 06-19-2025, 01:19 PM   #1
Portland , Oregon
Max length for Propane quick connect hose to BBQ?
I'm reviewing my options for a propane hose from my Airstream quick-connect outlet to my BBQ.
What's the longest practical (w/o losing too much flow) hose length for this application?
Thanks.
Cheers,
Bryan
blacklab is offline   Reply With Quote
Old 06-19-2025, 07:14 PM   #2
2016 19' International
Ft. Pierce , Florida
I ordered a hose from etrailer that was manufactured by MBSturgis. 100395-120-MBS. MB Sturgis Dual Quick Disconnect Propane Hose for Small Appliance - 10'. That was 8 years ago. I spoke with a rep from MBSturgis at the time to ask if I could hook another 10’ hose to make up a 20’ hose. They said they could do it but would not recommend it because the drop from the hose length and couplings would probably affect my stove’s performance. I would suggest you call MB Sturgis, detail what you have and ask for their recommendation. Sorry I have no definitive answer, but they should be able to help.
FLCoast is offline   Reply With Quote
Old 06-20-2025, 07:16 AM   #3
Portland , Oregon
FL Coast,
OK, thank you. I'll check with them.
Cheers,
Old 06-20-2025, 08:13 AM   #4
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
When I extend small LP hoses over 20' to my LP firepit, it works at first but then has pressure issues I assume from condensation in the line.
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 06-20-2025, 10:41 AM   #5
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
We have this 24' hose which works fine with the low pressure connection and our 3x30k BTU burner stove.
I'm a little curious why there would be much of a pressure drop over distance unless it's a leaky hose or connection.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 06-20-2025, 11:18 AM   #6
rd tighe's Avatar
2007 25' International CCD FB
South , South Dakota
Images: 13
? Long enough ?
We have a 20' hose and have not noticed anything we use it on a fire pit and our Webber Q . I guess I wasn't smart enough to think about it. Been doing it for about 3 years and love being able to get 20 foot from our rig.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Old 06-20-2025, 11:21 AM   #7
2000 25' Safari
2007 27' Safari FB SE
1995 25' Excella
Woodbine , Georgia
I don't know if I'm comparing apples to apples--but when we changed to a gas tankless water heater at home, we buried our propane tank approximately 50-60' from the water heater. The run to the heater is through 1/2" copper tubing and it feeds the water heater with no problems.
gamakai is offline   Reply With Quote
Old 06-20-2025, 01:43 PM   #8
2023 27' Flying Cloud
Byron Center , Michigan
20'
Use a 20' hose to both our propane bowl and to our Blackstone griddle. No issues.
2travelers is offline   Reply With Quote
Old 06-20-2025, 02:31 PM   #9
Custom User Title
Limnocnida's Avatar
Everett , Pennsylvania
Exclamation Hose woes
Blackstone to the onboard lp with (2) 12' rubber hoses and connections.
No issues, though maybe a smaller heat flame. We're considering using a Y-splitter for the generator for convenience.
Probably won't work at the same time.
Disconnect any rubber hoses overnight. Critters like to nibble.
***** Dangerous, especially if they chew through the main hose from regulator (under tanks). They did, so we replaced the rubber with braided steel.
ID:	454345   Click image for larger version
Limnocnida is offline   Reply With Quote
Old 06-20-2025, 02:32 PM   #10
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I think you are comparing apples and oranges as they say.
The 1/2" copper tubing from the propane tank at a residential installation is typically higher pressure (not full pressure) and is further regulated down to the working pressure at the point of use.
Regardless, the OP should consider a single length of hose rather than two hoses to eliminate any pressure drop associated with the added quick disconnect.
Having said that, several years ago when I wanted a 20' propane hose, all I could find at the time was two 10' hoses. My system works fine (at home, not on the trailer) with the two 10' hoses and the associated, extra, quick disconnect.
I second the knowledge at MBSturgis. I've purchased items from them in the past.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 06-20-2025, 04:34 PM   #11
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
I havce my port installed on the awning side, and have 3 12ft hoses and 1 y connection
#4286 "Stella" 2000 30ft Excella/Classic - Tow Vehicle - 2020 GMC Denali 1500 Duramax 3.0l Diesel, ProPride3 WDH.
previous tow vehicles 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement, 2005 Ford F150 Lariat 5.4L
Ultraclassic is offline   Reply With Quote
Old 06-20-2025, 08:27 PM   #12
1988 32' Excella
Robbinsville , New Jersey
From what I've read you can have a longer hose, if it is a larger diameter. Since the larger diameter would have less restriction. Also I was told this was the case with water hoses.
Old 06-20-2025, 08:39 PM   #13
Johnnyooo
Johnnyooo's Avatar
2015 23' International
Colrain , Massachusetts
I’ve been using 30’ of quick connect propane hose connected to my International serenity 23’ for 4 years with no problems whatsoever… It provides enough propane to grill everything from fish , steaks, and chicken.. I use it for cooking bacon in the morning and any thing else that needs grilling…
Johnnyooo is offline   Reply With Quote
Old 06-21-2025, 06:39 AM   #14
Redbarron55's Avatar
1985 25' Sovereign
Navarre , FL
I have been using a 25' extension from a quick connect I added at the rear bumper for a LP/ gasoline 2200 watt generator and it will produce full power from that outlet that is as far from the thanks and regulator as you can get.
Redbarron55 is offline   Reply With Quote
Old 06-25-2025, 09:27 AM   #15
2021 25' International
Ottumwa , IA
Hose Length
When i converted my new Q 2200 to low flow I had the same question and was told the reason for the 6 ft included hose was. 1) To keep the grill from under your awning and 2) Propane gas starts turning back to liquid after that length. Maybe that was misinformation but I've not had any issues.
Jeff Bittner is offline   Reply With Quote
Old 06-25-2025, 09:56 AM   #16
2022 27' International
Mont Vernon , New Hampshire
I'll bet there is greater loss with 2-10 ft hoses vs. a 20 ft hose due to the extra connector set.
TLowe43q is offline   Reply With Quote
Old 06-25-2025, 01:05 PM   #17
2023 27' International
Oceanside , CA
I use a 20’ hose all the time! If you want to use it on device that has a built in pressure regulator, it will need to be removed as the supply line coming from your rig is already regulated.
O-side Jimmy is offline   Reply With Quote
Old 06-25-2025, 01:07 PM   #18
Oceanside , CA
Does your fire pit have a built-in regulator? If so, it would need to be removed to use the extension hose.
Old 06-25-2025, 01:07 PM   #19
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
i have a 20' LP hose also, no issue
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,3x MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 06-25-2025, 01:58 PM   #20
Smh
2024 30' Classic
Truckee , California
We've been using two 20’ hoses for years now with no problems. 20’ to the Weber, Y fitting, then another 20’ from there to the Outland fire pit (its regulator removed).
Smh is offline   Reply With Quote
Exterior quick connect water hose and sprayer Dennis C Sinks, Showers & Toilets 17 03-19-2024 02:36 PM
Propane quick connect port and BBQ Pez Vela Sprinter and B-van Forum 1 08-01-2022 11:33 AM
Quick connect propane hose Leveille LP Gas, Piping, Tanks & Regulators 10 06-03-2022 12:55 PM
Maximum extension length for shore power? barrettjl Electrical - Systems, Generators, Batteries & Solar 37 06-06-2021 11:02 AM
Quick Question: 2016 Interstate sewage hose length Haasman Sprinter and B-van Forum 8 08-29-2016 11:13 AM
