2016 Airstream Interstate. The LPG quick-connect hose will not stay connected once the male hose is plugged into the female end. Owner's manual says to "release the collar and check that the hose is properly connected by giving a firm pull on the hose". It does not take much effort to pull it right out of the fitting. This is the connection which came with the unit.
You know that hoses come in two flavors- reduced pressure and full cylinder pressure? They look similar, but the high pressure hoses acts as you described when plugged into a low pressure fitting.
-Don (That man in that tiny can)
(Same man, Bigger can)
