Old 09-26-2020, 10:49 PM   #1
2014 25' FB Flying Cloud
Albany , Oregon
LPG port not working
Iím a newbie with a 2014 25í Flying Cloud and canít get any propane out of my external lpg port. I bought a custom 20í hose and while it connects nicely to both trailer and gas grill, I canít get any gas to flow. Even with the hose disconnected from the grill I canít smell any gas.
Iíve checked the piping from the tanks to the port and the only valve is at the port. And itís open.
Any clues?
FlyingCloud7 is offline   Reply With Quote
Old 09-26-2020, 10:59 PM   #2
2007 22' International CCD
Some propane male quick connect fittings look identical in diameter, and overall shape, and the retainer part (the large diameter Ďlumpí) is identical. Where the differences are is the overall length of the Ďnoseí of the fitting past the lump part that locks the fitting in place.
If itís too short for the female part of the fitting it will lock in place but not open the internal check valve and you will get no flow. Iíve seen compressed air fittings from different manufacturers that look fine, but donít fit right and cause the same issue.
Double check to be certain you have the exact right male fitting to match the other part.
Old 09-27-2020, 11:45 PM   #3
Albany , Oregon
Ok thanks. Appreciate the tip.
Old 09-27-2020, 11:56 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
There are fittings designated high pressure and low pressure. I bought a Camco fitting designated low pressure from Camping World. It would not mate with the hose that came with my Camco grill. It was in fact a high pressure fitting. I bought another fitting from Amazon and it worked fine.
ďYou cannot reason someone out of a position they have not been reasoned into"
Old 09-28-2020, 01:23 PM   #5
2019 27' Tommy Bahama
I think I know the problem!
Someone at an AS Rally told me that the hook up ONLY works with a straight hose, unregulated. (i.e. If you have ANY regulator between the stove and the trailer, it won't work - 'cause there is already a regulator up front at the two main tanks).
Mark of SJC is offline   Reply With Quote
Old 09-29-2020, 10:02 PM   #6
Albany , Oregon
We knew that part of it. Nothing we’re connecting to has a regulator on it. Pretty sure it’s simply the the male connector. Going by an AS dealer in slc tomorrow. Hopefully they can solve the mystery.
Thanks!
R
Exterior LPG port Rig Rat Sprinter and B-van Forum 20 09-25-2020 07:35 AM
Looking for LPG external port cap saraed LP Gas, Piping, Tanks & Regulators 15 09-21-2020 08:23 PM
Back-feed Propane through external LPG port Ė anyone do this? greghoro LP Gas, Piping, Tanks & Regulators 8 01-05-2018 10:09 AM
Exterior LPG Port Not working BradMarkB LP Gas, Piping, Tanks & Regulators 4 07-09-2016 06:08 AM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 08:57 AM
