Old 09-10-2024, 04:30 PM   #1
1975 31' Sovereign
milford , Michigan
LPG Hose Replacement / 1975 International
We noticed that the propane pigtails that run from the cylinders to the regulator weren't looking so good on our 1975 International, se we decided to replace them. Very straightforward job and I think I have that part handled.
Since these gas lines are about 50 years old, I figured it might be a good idea to ALSO replace the line that runs from the regulator (outlet) into the trailer. This one is proving to be a challenge.
I know that I'm replacing a 24" hose.
I know it needs to terminate in a 5/8 male flare fitting.
But I have no idea what the thread size or designation is for the regulator end.
Anyone know what size threads I need here? Or where I can just but the hose I need?
ID:	447246   Click image for larger version
ID:	447248   Click image for larger version
searchcz is offline   Reply With Quote
Old 09-10-2024, 10:07 PM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If you take that hose assembly to any reputable propane supply dealer they will be able to make you a new hose in a few minutes. In my experience the cost is not that much higher than if I sourced the parts myself and they can make sure the hose is correct.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is online now   Reply With Quote
Old 10-01-2024, 07:03 AM   #3
1975 31' Sovereign
milford , Michigan
So, I've run. around to every LPG and industrial supplier in town ... with no luck so far. For others who might want to know, I have learned that the regulator side of this hose is a 3/8 tapered pipe thread, so at least I now know what I'm looking for.
Old 10-01-2024, 10:02 AM   #4
nelsonh's Avatar
2023 23' Flying Cloud
Carroll , Iowa
You beat me to it... I was about to suggest that is probably 3/8" NPT, which is nearly a standard thread size on gas fittings like these (although 1/4" NPT is also sometimes used).
2023 Flying Cloud 23FBT ~ 2024 Ford F150 XLT PowerBoost 7.2 kw ~ 2010 Border Terrier
nelsonh is offline   Reply With Quote
Old 10-01-2024, 10:08 AM   #5
1994 25' Excella
Have you taken it to places that build custom hoses?
Richard
11018
Old 10-01-2024, 10:21 AM   #6
nelsonh's Avatar
Carroll , Iowa
I would check on etrailer.com
If you have time to wait for shipping, you should be able to get everything you need from etrailer, they have a pretty full selection of LP hoses etc:
https://www.etrailer.com/dept-pg-Pro...Feet_Long.aspx
LPG extension hose for Blackstone doughpat LP Gas, Piping, Tanks & Regulators 11 10-14-2023 12:51 PM
LPG Extension Hose Help Blighcapn LP Gas, Piping, Tanks & Regulators 3 10-07-2020 05:59 AM
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 10:41 AM
LPG tank 1975 Argosy 28'? DanKlein Argosy Motorhomes 3 04-04-2016 09:04 AM
LPG Tanks, Fittings, Servicing, Replacement morlach Classic Motorhomes 8 11-06-2014 08:38 PM
