07-03-2017, 05:42 PM
2017 25' Flying Cloud
Florence
, Alabama
Lp tank check feedback
For those that have had the tank check for a while, do you recommend, is the monitor panel working right? Would I be ok to just get the sensors and use with phone, assuming there is an accuracy problem with panel? Thx
The Colonel and Southern Belle
07-03-2017, 05:49 PM
2017 30' International
Broomfield
Accuracy is the same wth phone or monitor. Actually I think the monitor only reports in 20% increments and phone app is in 1% increments, but ultimately either device will simply report back what the sensor is sending.
I use them and like them. No problems to report here. Takes the guesswork away regarding how much fuel you have on board.
07-03-2017, 06:47 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
I didn't bother to hook up the monitor and am just using my iPhone. Seems to work well. One question I have is how long will the batteries in the sensors last? Since I just installed the sensors last week I'll have to wait and see I guess.
It's nice to not have to guess how much gas is in the tanks!
07-03-2017, 07:15 PM
Biloxi
, Mississippi
I have my senders synced to both my iPhone and iPad. I did not buy the monitor. Only issue I have had was a Tank 1 sender that was eating batteries. It came with a dead battery and 100% discharged 2 in 2 months. The other sender was still showing full battery charge. I called the company and they quickly sent me a new replacement sender and the redesigned aluminum feet for both tanks.
MICHAEL
07-04-2017, 11:36 AM
2013 25' Flying Cloud
Wheaton
What LP tank check are you referring to in this thread?
Greg
07-04-2017, 11:38 AM
Tavares
Greg
This one. http://mopeka.com/products/
07-04-2017, 12:01 PM
Florence
, Alabama
What Hans said, that's what I asked about.
07-04-2017, 01:29 PM
Giovanni
2015 28' International
St Helena
Hi
Thanks for the info. Does this system work on Aluminum tanks? I see they have magnets to attach to the bottom...
07-04-2017, 01:33 PM
Tavares
I don't see how this specific sensor would work on aluminum tanks as they require steel for the magnets to attach.
Not sure if there is a way around this issue.
07-04-2017, 03:43 PM
Biloxi
, Mississippi
There are few problems that Duct Tape can not fix. I would try Gorilla Duct Tape. That stuff will just about stick to anything.
http://mopeka.com
The company has excellant customer service and can be contacted at 800-874-3271.
MICHAEL
07-04-2017, 04:15 PM
2016 25' Flying Cloud
Albuquerque
, New Mexico
I put the Mopeka System on my two 30 gallon tanks a couple of months ago and love it. Like previous posters said, it takes the guesswork out of the last thing that needs monitoring in the Airstream.
Customer service is great as they sent me two Tank 1's initially. When I called, they immediately sent me the missing Tank 2 monitor.
As for sticking with duct tape, I'd contact Mopeka first. There was a small piece of film over the magnet that had come off and the sender didn't work. Once I noticed it and put the film back over the magnet, everything worked properly. I guess it is pretty sensitive.
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
07-04-2017, 06:25 PM
Retired paddler
1993 29' Excella
Brighton
, Ontario
Thanks for the link. Gonna have to try this on my two horizontal tanks.
Cathy and Hans
1993 Excella 29' w/Hensley
2011 GMC SIerra 2500HD SLT
07-04-2017, 08:33 PM
2008 27' International FB
Venice
What kind of Aluminum feet! New to me. I also have aluminum tanks and want to attach the sensors to the bottom of the tanks. What to do?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
07-06-2017, 09:23 AM
Tavares
To provide clearance for the sensors that are attached to the bottom of the tanks "feet" (actually spacers) are provided with the sensor kit. The original "feet" were made of hard plastic and apparently they didn't hold up well during real world use. so the company realized the error and will provide aluminum replacement "feet" if you call them and make the request.
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
07-07-2017, 08:26 AM
Biloxi
, Mississippi
I have had my Tank ✔️for just few months. My original feet were a soft spongy rubber not hard plastic. I would expect that they are shipping new sensors with the new aluminum bases. Current old stock probably still have the soft rubber feet.
MICHAEL
07-07-2017, 09:27 AM
Tavares
I stand corrected when I said the feet were made of hard plastic. I didn't really look at them knowing that the aluminum feet were on the way!
09-08-2017, 02:41 PM
2011 22' Sport
Portland
, Oregon
Another Tank Check user that is pretty happy, I have a Sport 22FB which has no avenue of LP monitoring and the 20# tanks are pretty convenient, as worst case I can exchange them. I ordered two Tank Check sensors with a monitor, actually I had ordered the kit with the monitor and an additional sensor not realizing the "kit" actually had 2 sensors in it. I used the 3rd sensor on my home propane grill, which didn't require spacers as the tank sets in a slide-out tray that has plenty of space below it.
I had a heck of a time trying to get the sensors to work on the AS though, as I'd get it position and it would be fine...but as soon as I went to set it back into the tray the rubber feet would all off, or they would over-compress and the sensor would stop reading. I contacted Tank Check, and their customer service was top notch and agreed to send me the other replacement spacers.
However I decided to look for other options and found the Tank Tire and ordered that to use as a spacer instead. It fits over the entire circumference of the tank "foot". It enlarged the foot too much to fit into my tank tray as-is, so I just grabbed a pair of vice grips and widened the top of the tray a little bit. The tanks are quite snug in their place, the sensors work, and I don't have to worry about being able to easily get the spacers back in the right place if I ever did an exchange...in fact now I don't have to worry about setting the tank down wrong and damaging the sensor while getting a refill either.
I mounted my Tank Check monitor above my Micro Pulse monitor and have the tanks programmed so that the curb side monitor button corresponds to the curb side tank. Obviously you could just skip the monitor entirely, but I like having the trailer be self sufficient and not dependent upon *my* phone.
No affiliation with either company, but I like to share good products with others. http://www.tanktire.com
10-06-2019, 07:56 AM
Journeyman
2016 25' International
Amherst
, Massachusetts
Very happy with my Mopeka system... and I too used the tank tire. It looks like Mopeka has come up with their own version which may be as good and is quite a bit cheaper.
Haven't used it but it's here:
https://www.amazon.com/Mopeka-Tank-C.../dp/B07HQZRR9F
10-06-2019, 08:18 AM
Tampa
I know Airstreamers like hi-tech, but try this:
Pour a cup of warm/hot water over the tank, then slide your hand down the side. You will feel a line perfectly. (More than you'd believe.)
