Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-27-2021, 08:11 AM   #1
1973 23' Safari
Germantown , Tennessee
LP Line protection entering belly pan
What is the black tubing covering the LP line as it goes into the bellypan? I can't seem to find a replacement for it. Does anyone recommend a modern product for this?
lojoma is offline   Reply With Quote
Old 10-27-2021, 08:15 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I've used a split length of rubber fuel line for things like this in the past. For larger tubing, smaller diameter heater hose works, but this looks like fuel line would be a better fit.
Usually I've split the rubber fuel line in a straight line down the length, but in a case like this where there is a bend sometimes I've split it in a slow spiral so that it bend better. Add a few zip ties to hold it in place and a bit of new caulking and you're all set.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is online now   Reply With Quote
Old 10-27-2021, 08:44 AM   #3
Rich W's Avatar
I'm In , Kentucky
Looks like the insulation used on hot water lines or A/C lines. Lowes and Home Depot carry it in the plumbing department. I think it comes in a couple different diameters, about 6' lengths I think. It's split lengthwise.
Here are two of them. The top one has a pull away strip to allow the stick-um to seal it back to the tube. Make sure you've got it the way you want it before you pull the strip off. Once it touches the rubber it won't let go except to tear off a piece of the rubber. The bottom one would need tape or zip ties to keep it in place.
https://www.lowes.com/pd/Frost-King-...lation/3132299
https://www.lowes.com/pd/Frost-King-...ion/1001277248
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 10-27-2021, 09:54 AM   #4
1973 23' Safari
Excellent, thanks.
Old 10-27-2021, 10:18 AM   #5
1970 23' Safari
Denton , Texas
So if you do this, aren't you containing potential leaks? How about clear tubing, and as short as possible - to protect impact points and entry points only?
Texas Fly Caster
Loco Airstreamer
shannon is offline   Reply With Quote
Old 10-27-2021, 10:24 AM   #6
2015 20' Flying Cloud
Lander , Wyoming
The newer units use PEX tubing to protect gas lines. Itís super tough and will resist rock damage far better than foam insulation. Use 1/2-inch PEX for the gas lines on the Airstream. PEX can be split with a razor knife and slipped over the gas lines, then held in place with wire ties or small hose clamps.
Wetfeet is offline   Reply With Quote
Old 10-27-2021, 12:05 PM   #7
1959 24' Tradewind
Twin Falls , Idaho
Grommet
I would just use a grommet to protect it. Make the bend 90 degree's. I don't know why you would want/need to 'angle' a gas line like that.
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 10-27-2021, 01:54 PM   #8
1994 25' Excella
Grommets slip and move around. There is nothing wrong with using a short length of rubber or pex tubing to protect the copper gas line. It won't trap any leaks - they would still be quite noticeable.
My coach has many fuel and water lines protected like this from the factory. They used a rubber impregnated canvas to do this at the factory in 1974, but when the shop works on those lines it's replaced with rubber tuning.
The goal is simply to move the rub point from the copper line to the rubber. When the rubber starts to wear it gets replaced.
Richard
11018
Old 10-27-2021, 03:23 PM   #9
2021 25' Flying Cloud
Woodbury , CT
LP hose
This is what is used on my 2021 FC.
I guess you might have to re run all the lines though since it is a bit different.
https://www.flextechhose.com/1-2in-h...-lpg-hose.html
stevegilmore is offline   Reply With Quote
Old 10-27-2021, 04:41 PM   #10
1966 22' Safari
Fredericksburg , Texas
We just used 3/4Ē water hose. But did not cover the joints or valves. Strapped the hose to the bottom of the belly pan. Works fine for us. Good luck
Bubba L is offline   Reply With Quote
Old 10-28-2021, 11:39 PM   #11
1973 23' Safari
Thanks everyone! I appreciate the input!
Old 11-03-2021, 06:51 PM   #12
1954 22' Safari
Bellefonte , Pennsylvania
Originally Posted by Wetfeet View Post
The newer units use PEX tubing to protect gas lines. It’s super tough and will resist rock damage far better than foam insulation. Use 1/2-inch PEX for the gas lines on the Airstream. PEX can be split with a razor knife and slipped over the gas lines, then held in place with wire ties or small hose clamps.
I am replacing the gas lines in my '54 Safari using 1/2" PEX from the belly pan entry up through the plywood floor as a protective sleeve.
I do not plan to encase the entire gas line. If a leak occurs in an encased pipe the gas can travel within the casing and possibly enter the interior of the RV.
Leaks should be free to vent away.
fiftysafari is offline   Reply With Quote
Old 11-03-2021, 07:20 PM   #13
1994 25' Excella
The plywood will certainly be better than the sheet metal, but I'm not sure it will accomplish the same thing as wrapping the copper with something.
When a protective layer like a piece of PEX tube is put over the copper line it moves the rub point from the copper to the PEX. The PEX will move with the copper and any abrasion will occur between the wood and/or sheet metal and the PEX. With the setup you're describing, you'll still have abrasion between the copper and something, it's just you've reduced the abrasion from metal to wood.
Richard
11018
Old 11-03-2021, 09:07 PM   #14
1954 22' Safari
I may not have been clear.
My lp gas line will be encased in PEX tubing from where the tubing enters the belly pan up through the flooring to protect the tubing from rubbing the belly pan or the flooring. Abrasion cannot be entirely eliminated but the PEX will protect the copper tube.
Cheers!
Old 11-03-2021, 09:13 PM   #15
1994 25' Excella
Cheers!
Makes sense. Thanks.
Richard
11018
Old 11-03-2021, 10:13 PM   #16
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
A piece of old garden or lawn hose, cut and put around line, held with zip ties works very well also.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 11-04-2021, 07:31 AM   #17
Antsville , FUBAR
YEP...MacGyver approved. Did the same on our first AS.
Tuck the side belly wrap under the flat belly pan or the other way around? haaseome Belly Pans & Banana Wraps 4 08-24-2021 12:34 PM
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 08:41 PM
Tips/Info for Entering Canada w/an Airstream mjaw On The Road... 18 08-28-2007 12:26 PM
Entering the Generator World... cynthia Generators & Solar Power 6 05-07-2005 12:11 AM
Breaking & Entering Navigator Doors & Locks 4 02-28-2004 08:34 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
