RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-02-2018, 11:31 AM   #21
Dogs Rule
2019 19' Flying Cloud
Liberty Hill , TX
LP tank to external grill
Have a Nest & like it, alot. Now I want to add an external grill (like a Weber Q2200) and use the 20 lb tank installed on the Nest. There is an existing quick connect and valve to this set up. I have the hose with the male quick connect to the existing female quick connect.
Question is what fittings are needed to connect the hose to the grill?
Anyone accomplished this?
Jcpelton is offline   Reply With Quote
Old 08-02-2018, 11:42 AM   #22
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Why did you post this in two different threads?
Ray B.
Adventure.AS is offline   Reply With Quote
Copper compression fittings vs. flare fittings MR AIRSTREAM LP Gas, Piping, Tanks & Regulators 37 12-07-2015 04:08 PM
How to test gas pressure and bleed gas lines? maggieevans LP Gas, Piping, Tanks & Regulators 12 09-25-2013 07:02 AM
New gas lines and pressure tester Splitrock Stoves, Ovens & Microwaves 2 08-29-2010 08:12 PM
A question on underbelly skin and its gas lines. soldiermedic Belly Pans & Banana Wraps 12 11-23-2006 04:34 PM
