04-26-2022, 07:54 PM
Anchorage
, Alaska
LP gas line
I am picking up a project started many years ago, and can’t quite remember how things were put together.
I am working on a 1963 Bambi
As I recall, there was room for propane tanks on the tongue, and a hard gas line running outside the belly pan to the back of the trailer, where the line came up through the floor to the appliances.
What should I used for that hard line under the belly pan ? Is that 1/2”-5/8” soft coiled copper pipe ? What is the best material to use ? Is outside the belly pan, still the industry standard ?
04-26-2022, 08:06 PM
2019 22' Sport
High River
, Alberta
⅜” copper is what you want. You will need a good flaring tool. Yes, these lines need to be installed under the belly pan.
Natural gas rises and dissipates, but propane is heavier than air. If you have a leak, you want the gas to drop and be blown away by the breeze. Having it trapped between the belly pan and the floor doesn’t seem like a good thing.
04-26-2022, 08:57 PM
1966 22' Safari
Fredericksburg
Like Albert said, outside the belly pan for the trunk line and connections. It’s required. I’m helping a friend of mine now renovating a 63 Bambi. We’re not to the propane installation yet, but close. There is plenty of room on the tongue for a couple of tanks. On our other two trailers, we used a 1/2” in trunk line and installed valves where we would T off with 3/8” to each appliance . I think we used soft L-copper. I like a valve below the belly pan for each appliance. You are only talking about a stove top, hot water heater and possibly a fridge. I did protect all copper lines underneath by splitting water hose and tie-wrapped around the lines. Hope this helps. Good luck. (Oh, I did use double flares due to vibration. Ew test and haven’t had a leak. Knock on wood).
03-18-2023, 11:41 PM
Anchorage
, Alaska
Pulling up my old thread
Are there any videos on how to attach the copper hard line to the regulator ? And I guess it will be a similar process to attach the copper hardline to flexible lines & appliances.
03-19-2023, 11:13 AM
1994 25' Excella
Waukesha
, Wisconsin
My copper line connects to a flex line, and the flex line connects to the regulator.
Richard
11018
03-19-2023, 01:58 PM
Anchorage
, Alaska
Thanks richard5933, but that still leaves me with the question, how to attach a hard copper line to: a flex line, appliance, regulator. I’ve got to stop by a shop that does hydraulic fittings for another of my projects. I’ll bet they attach hard lines to all kinds of stuff. I’ll ask them about this as well.
03-19-2023, 03:30 PM
1994 25' Excella
Waukesha
, Wisconsin
Might be better going to a propane shop rather than a hydraulic shop - they use different fittings on propane lines. Connecting a flex line to copper lines is pretty common in the propane world, and the guy at the shop in Milwaukee I went to didn't hesitate when I asked for something similar to what you're asking - he went to the back and came back with a handful of parts.
Richard
11018
03-19-2023, 05:56 PM
Anchorage
, Alaska
