Old 02-22-2021, 08:55 AM   #1
AL’ UM- MONEY's Avatar
1976 31' Sovereign
2000 33' Land Yacht
Ball Ground , Georgia
LP fill up on internal tanks
New to this,all my experience is with 20/30 pounds tanks. My third AS but now a Land Yacht. Any issues with filling up the internal tank. Are there date restriction or certifications on these horizontal tanks. Seems like others are getting hard with certain rules, didn’t know about these.
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
AL’ UM- MONEY is offline   Reply With Quote
Old 02-22-2021, 10:04 AM   #2
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Motorhomes have fixed-mount tanks and fall under different rules in the US. For starters, there is no recertification period. They're permanent.
Which is not to say that they can't deteriorate. Responsible licensed fillers will be able to observe that a tank is in good shape (no deep result, cracked mounts, dents, etc.). And if it is in bad shape, she or he is encouraged not to fiddle with it.
For the most part, though, you should be able to see damage by yourself. And if it is in sorry shape, don't try to sneak it by. Get it replaced at a full-service propane company.
So, then, the filling process is easy. You take it to a propane filling outfit and have the person fill it. You'll need to have all propane appliances turned off; all humans must leave the moho; and the wheels must be chocked. The filler will use the bleed valve to determine the full point (i.e., fill by volume), there being no reasonable way to fill by weight instead.
Lynn
ACI Big Red Number 21043
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 09:34 AM
Where to fill water tanks on the road? Hibby On The Road... 17 10-05-2010 06:58 AM
"500 INTERNAL SERVER ERROR" messages richinny Forum Admin, News and Member Account Info 4 04-23-2008 08:53 AM
infernal, internal condensation austin Winter Living 14 09-24-2006 09:56 AM
internal charge wizard or external dragonnfly Electrical - Systems, Generators, Batteries & Solar 8 07-12-2006 02:18 PM
