Old 07-16-2020, 08:41 AM   #1
saraed's Avatar
2016 27' International
North Augusta , South Carolina
Looking for LPG external port cap
The blue plug that was in my external LPG port disintegrated and crumbled to pieces when I removed it. Right now I have electrical tape on it to keep crud out of it, but that is not a long term solution. Has anyone found a cap you like for your external port?
saraed is offline   Reply With Quote
Old 07-16-2020, 08:47 AM   #2
2019 27' Globetrotter
Salem , Oregon
Check with a propane supplier or possibly Home Depot or Lowes in their grill accessories.
Also AMAZON should be able to fix you up.
Dave
NoResults is offline   Reply With Quote
Old 07-16-2020, 02:01 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
https://www.google.com/search?q=prop...nect+dust+plug
TheGreatleys is offline   Reply With Quote
Old 07-16-2020, 03:29 PM   #4
Long Island , New York
Thanks for that very simple solution.
Peter
Old 07-16-2020, 05:43 PM   #5
saraed's Avatar
Thanks for the suggestions, everyone.
Old 07-16-2020, 08:27 PM   #6
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
I bought some hose extensions and each one came with a blue cap. I have about 3 extra. You could have one of mine if you were closer.
Perhaps a BBQ shop or RV shop can give you one. They are not in short supply!
PB_NB is offline   Reply With Quote
Old 09-17-2020, 07:40 AM   #7
2019 25' Flying Cloud
La Conner , Washington
Hope you found those replacement caps.
Have you discovered what the External LP supply is even for?
1) That fitting doesn't take the usual LP hose connector.
2) Once that is solved, one finds that it is regulated gas and a typical Weber type LP BBQ has a regulator on it. Then one finds out can't have two regulators, so must remove the Weber reg and find the right fitting again.
Very disappointing. I was told by an AS repair shop that most people just by the 1 lb disposable cans.
So what is the friggin thing for in the first place?
George
Blighcapn is offline   Reply With Quote
Old 09-17-2020, 09:13 AM   #8
2007 22' International CCD
George
Itís great for running generators and grills that have the appropriate connector.
My 2007 did not have one, so I added one.
My champion generator plugs into it.
And runs just fine.
Old 09-18-2020, 10:19 AM   #9
Thanks for responding. I guess what I would really like to know is how to adapt the Ext LP to a hose that could supply a BBQ AND how to remove the regulator and connector on the BBQ and replace it with an adapter that can fit the end of a standard 12ft. LP hose.
This hose did not attach to the Ext LP and of course I did not know the BBQ regulator had to be removed.
Old 09-18-2020, 02:35 PM   #10
Search the forums a bit. Itís been discussed often. I donít have a BBQ so Iím no help...you could take the BBQ and the Airstream to a propane supplier and see if they can adapt it properly.
Old 09-19-2020, 07:51 AM   #11
Thanks, I did search the forums but did not see a rec for the right adaptor at the trailer end of the hose.
But, to take the trailer and and the BBQ.... might be easier to just by a few l lb cans of LP.
George
Old 09-19-2020, 08:30 AM   #12
2019 30' Flying Cloud
Homosassa , Florida
I went to local Ace Hdwe.and got a male end that fits the adapter. They had all pieces.
Tater is offline   Reply With Quote
Old 09-20-2020, 04:51 PM   #13
On my 2019 FC 25 the external LP fitting IS the male end. I can't get a standard lP hose to go on it.
Old 09-20-2020, 08:08 PM   #14
Homosassa , Florida
Check with Ace Hdwe. They should have both ends for the quick connect. I'm sure other Hardware stores may have them as well. I haven't checked Amazon but they may also. Good luck.
Old 09-20-2020, 09:23 PM   #15
Note that the connector on the propane system on the A-frame should be a female connector with a check valve inside it plus a shut-off manual valve. See below for a picture of my female connector with the yellow handled shut off valve behind and below it.
The male part (goes into the female part) should be on the extension hose. If yours is not set up like that, something is seriously wrong.
Note that the Champion dual fuel inverter generator I have does use a smallish female quick connector on the generator front panel for propane, and a male quick connector on the hose from the regulator. It is set up weird...but works fine.
K
Old 09-21-2020, 08:23 PM   #16
2017 23' Flying Cloud
Canton , Georgia
I have a WeberQ grille that I just converted to use the LP connector at the front of the Airstream. I got a conversion kit on Amazon and watched a YouTube video. It took about 10 minutes to remove the Weber regulator and install the conversion kit. The kit was $48.
Philly Dave is offline   Reply With Quote
Exterior LPG port Rig Rat Sprinter and B-van Forum 20 09-25-2020 07:35 AM
Back-feed Propane through external LPG port Ė anyone do this? greghoro LP Gas, Piping, Tanks & Regulators 8 01-05-2018 10:09 AM
Exterior LPG Port Not working BradMarkB LP Gas, Piping, Tanks & Regulators 4 07-09-2016 06:08 AM
2016 classic external LPG connector jvcolaizzi 2016 - Current Classic (all lengths) 1 03-31-2016 10:56 PM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 08:57 AM
