Old 06-29-2020, 10:20 PM   #1
2002 25' Safari
Salisbury , Maryland
Is the hot water tank ignitor supposed to continuously click?
So I have a new to me 2002 Safari with an Atwood G6A-8E 6 gallon lp water heater.
Ok so, it has been back firing when I have been trying to light it so I cleaned all the connections (they are pretty bad) as best I could at the time. Nothing really happened. Then I started messing with the airflow pipe and I got it to light a nice blue flame. The only problem is that the ignitor keeps on clicking like it's trying to ignite the lp even though it's already produced ignition. You can hear it every couple seconds.... Click click click click. Then stop, then a few seconds later click click click click. Now I'm 99 percent sure this is not normal operation and my automotive experience would point to the electric box the ignitor is plugged into? Am I on the right track here? I don't like throwing parts(spell check said throwing farts for some reason) at broken objects so any guidance would be appreciated.
Munk.
MunkMaster is offline   Reply With Quote
Old 06-29-2020, 11:16 PM   #2
2002 19' Bambi
Lafayette , California
It should not keep clicking. Checking the airflow was a good thing to do. I suggest making sure there are no spider webs in the burner area. The control board may be shot. If so, consider installing a Dinosaur board instead of one from the manufacturer.
Tim
Tim A. is offline   Reply With Quote
Old 06-29-2020, 11:40 PM   #3
2002 25' Safari
Originally there was a wasps nest in there but I took it apart and cleared the inlet tube. I had read a small amount about the dino board. Thanks for the info. I'll make sure to order that board soon
Old 06-30-2020, 05:53 AM   #4
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Munk,
Not firing up the parts cannon? Good. This might give you some suggested reading.
https://myrvworks.com/wp-content/uploads/2019/04/ WaterHeaterManual.pdf My RV works has additional docs.
In the sequence of operation (see page 16) the control board opens gas valve and sends power to make the spark, flame starts and then the same thing that made the spark senses the heat from the flame and sends signal back to board ALL's OK keep the gas on. But sounds like your's is keeping the gas valve open and continuing the spark ?
Just as a can do w/o any $$$ power off to tank, see the connections that go to the $$$ control board? pull each off carefully and very light (pencil eraser) cleaning of the terminals on the boards and reinstall the connectors. Can't hurt.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 06-30-2020, 05:57 AM   #5
Sag Harbor , New York
Check the location of your thermocouple, the small metal probe which sticks into the flame to alert the "brain" if the flame goes out. Sometimes the support arm gets bent out of place during maintenance work.
https://www.gvpropane.com/propane-he...oubleshooting/
Good luck,
Old 06-30-2020, 11:38 AM   #6
2010 19' International
Bellevue , Washington
Flame on sensor
The control board senses that the flame is on by passing an electric current through the carbon rich flame according to a uTube video. Here are links to two I found helpful. One of the videos is specifically about the Atwood 6 gal water heater in the Airstream. Dometic/Atwood RV Water Heater Overview, Burp, And Backflush Here is the other: Broken Atwood RV Water Heater (Troubleshooting and Repair) You are already on the right track but these two videos are interesting. The control board is likely bad but it could be the wire from the flame sensor to the control board.
cwm49 is offline   Reply With Quote
Old 06-30-2020, 03:54 PM   #7
Backfortyjoe's Avatar
2019 20' Flying Cloud
Eau Claire , Wisconsin
I had the same trouble on the same Atwater water heater. Every time I fooled with it I had a different system. I replaced the control board with the Dinosaur board and has been working well now for 3 years. Try it, you’ll like it. Easy to install. There is one jumper on it that you plug for a gas/electric or just a electric only!
Backfortyjoe is offline   Reply With Quote
Old 07-01-2020, 07:33 PM   #8
2002 25' Safari
Awesome info. Thanks for the videos too.
I removed and cleaned to connections and no change. I cleaned the ignitor and no change. Next step is to order the Dino board.
Thanks again
Old 07-19-2020, 09:50 PM   #9
2002 25' Safari
Ok since we all agree the Dinosaur board is the fix. I see that there are different versions of these said boards. I emailed the company and haven't heard back from them. Does anyone know how to match the correct board to your water heater?
Old 07-20-2020, 08:24 AM   #10
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I fought my water heater from the time my Airstream was brand new off the lot. Four years later, I finally bought the Dinosaur board, installed in in 20 minutes and it works fine now.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 07-20-2020, 08:31 AM   #11
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Look It Up Chart
http://www.dinosaurelectronics.com/UIB_Chart.htm
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 07-20-2020, 09:10 PM   #12
2002 25' Safari
Originally Posted by SeeMore View Post
Thanks, I saw that page but none of the numbers on my heater or board match anything on that page. So that's where I am scratching my head. It board does seam original.
Old 05-31-2021, 09:39 AM   #13
GARLAND , TX
MunkMaster did you get your Atwood answer?
Hello MunkMaster,
Did you ever get your igniter fixed on your Atwood hot water heater? We have same issue. Thanks!
Cheryl Mize is offline   Reply With Quote
Old 06-04-2021, 08:47 AM   #14
GCinSC2's Avatar
Originally Posted by Cheryl Mize View Post
Hello MunkMaster,
Cheryl Mize,
Welcome to Airforums.
You might want to start a new thread to get help with your issue. Please include the trailer year and model and a description of the problem.
Simple stuff to check, does the stove light? That sorta proves system can supply gas. Also pics of anything interesting at the water heater itself that catch your eye.
There are many good YouTube videos at My RV Works https://myrvworks.com/ and service manuals at Darren's resource tab on his website. Diagnosing the water heater or furnace a big help is understanding the basic component function and a step 1-2-3 for how they work.
Gary
S/OS #001
click click click is all I hear! ericjan2 Electrical - Systems, Generators, Batteries & Solar 10 07-20-2013 10:29 AM
AC/heat pump runs continuously unless shut off manually lsinclair Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-13-2010 08:47 PM
Water Pump Runs Continuously craftsman Water Heaters, Filters & Pumps 6 12-01-2009 12:38 PM
click click kepko Generators & Solar Power 0 05-29-2009 01:54 PM
water heater ignitor ground john hd Water Heaters, Filters & Pumps 14 08-26-2006 09:58 PM
