RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-12-2018, 06:21 PM   #1
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Spring , Texas
Inverter Flare or NPT Pigtails?
I am really confused - we have a Cavagna 2 stage auto changeover regulator & I cant figure out which type of pigtails they are?
I have attached a picture - please help.
Glenn
PSU1981 is online now   Reply With Quote
Old 06-12-2018, 06:55 PM   #2
Kevin245's Avatar
Typically the outlet is 3/8 inch NPT. Check your model number against the manufacturer's specification sheet for confirmation though.
http://www.cavagnagroup.com/wp-conte...-rev2-2012.pdf
William C. Swinney
Old 06-12-2018, 07:14 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Those are pipe thread pigtails.
Old 06-12-2018, 07:22 PM   #4
PSU1981
PSU1981's Avatar
Spring , Texas
Kevin - thanks!!! I have a Type 924 NRV it says Outlet connection is 3/8 NPT.
Is the outlet connection where the pigtails screw into the regulator?
Old 06-12-2018, 07:28 PM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
The hose has a swaged on 3/8" npt thread fitting, not to seperate.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 06-12-2018, 07:33 PM   #6
PSU1981
PSU1981's Avatar
Spring , Texas
Thanks!!!
Old 06-12-2018, 08:04 PM   #7
PSU1981
PSU1981's Avatar
Spring , Texas
Do the pigtails screw into the inlet or outlet connection?
Old 06-12-2018, 08:20 PM   #8
Kevin245's Avatar
The pigtails thread into the outlet ports.
William C. Swinney
Old 06-12-2018, 08:23 PM   #9
PSU1981
PSU1981's Avatar
Spring , Texas
Ok - just seems backwards since gas is flowing from a tank into the regulator then out to the AS....
Old 06-12-2018, 08:28 PM   #10
Kevin245's Avatar
Actually Iím backwards (not the first time either I might add). The outlet is the single. The inlet is the double. Refer to the photo of your regulator in the pdf file.
William C. Swinney
Pigtails and brakes 1977 Ambassador MACINRIC Towing, Tow Vehicles & Hitches 4 11-02-2015 12:04 PM
Replacing pigtails on'86 32' excella rbhinzman LP Gas, Piping, Tanks & Regulators 1 08-25-2014 12:00 PM
Marshall pigtails with 3/8" male fitting 2goldens LP Gas, Piping, Tanks & Regulators 4 04-03-2014 10:46 PM
Need Quick Disconnect Battery Pigtails sharris1199 Batteries, Univolts, Converters & Inverters 9 08-05-2009 11:46 PM
Old 1/4" pigtails don't fit new 1/4" regulator? longdog LP Gas, Piping, Tanks & Regulators 1 04-22-2009 09:56 PM
