RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-24-2020, 03:57 PM   #1
1972 23' Safari
Middletown , Rhode Island
inline shut off gas valve necessary...
I think I have a leak from my back inline gas valve right before my water heater, is it necessary to have a gas shut off valve or can I just eliminate it. I have a 72 Safari. Thanks.
Mx468 is offline   Reply With Quote
Old 08-25-2020, 11:16 AM   #2
1972 23' Safari
I'm going to bypass it...
Answer to my own question, is I am going to just bypass it, also because I hear that the new airstreams do not come with the inline shutoffs. Correct me if I am wrong, bueller? bueller?
Old 08-25-2020, 11:22 AM   #3
2007 22' International CCD
The only inline shutoff valves I have on my 2007 are ones I installed. One is a cutoff before a quick disconnect fitting I added for my generator, and the other is a master shutoff for all propane coming from the regulator.
Generator connector and valve. Valve is used to shut down the generator. Champion does not shut off with ignition switch when running on propane. Using this valve letís the generator burn off the propane in the lines for safety.
Master shutoff installed just after the hose from the regulator. Makes it easy to quickly shut off all propane to Airstream appliances in case of a leak without trying to get to the cylinder valves inside the tank cover.
Gas Shut off valve ninefingers Electrical - Systems, Generators, Batteries & Solar 0 07-12-2014 01:48 PM
Inline Propane Shut-off Valves?? SLNugget LP Gas, Piping, Tanks & Regulators 8 09-14-2012 11:52 AM
Gas valve shut off help slimitch Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-06-2008 04:04 PM
1986 AS 345 MH Magic Chef Shut off Valve? Jim Tyrney Stoves, Ovens & Microwaves 2 10-14-2003 02:48 PM
Shut off valve, 1992 30' Motorhome dwc Mechanics Corner - Engines, Transmission & More... 0 07-01-2002 05:50 AM
