RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-03-2018, 03:22 PM   #1
Arnoldter's Avatar
2016 27' International
Frisco , Texas
I have a 2016 27 FB International My propane hot water heater will not stay lit.
My exhaust screen and up the side is black with soot. First time using propane in a year or so. What causes this? And is it ok to use electric on the hot water heater? Thanks
Arnold and Amy Terkel
2016 27FB
2016 Chevy Silverado 1500
Arnoldter is offline   Reply With Quote
Old 07-03-2018, 04:08 PM   #2
2007 22' International CCD
That's an clear indication of a mud dauber or wasp nest in the water heater flue between the burner and the exhaust port. It blocks proper flow, and causes the soot and possible flame blow-back if bad enough. Inspect carefully for blockage.
Open up the cover and clean it out with a long flexible brush and compressed air. Wear eye protection and expect to get dirty, as there may be a lot of 'stuff' in the tube, and it will go everywhere at high speed when you hit it with the air. Make sure ALL the burner parts are cleaned out before you try to light it again...
Some folks have had success using a piece of dog flea collar inside the water heater enclosure to keep the bugs out. There are also after-market screens made to keep bugs out of the water heater and furnace exhaust vents and air intakes. The propane smell seems to attract certain bugs, and they build nests in your appliances.
Water Heater will not stay lit on gas rbs Water Heaters, Filters & Pumps 5 06-19-2012 12:03 PM
Gas Water Heater Won't Stay Lit somefun LP Gas, Piping, Tanks & Regulators 13 11-02-2010 05:32 PM
Water Heater will not stay lit Beginner Water Heaters, Filters & Pumps 8 04-01-2008 02:08 PM
Water heater wont stay lit at high altitude Airstream25 Water Heaters, Filters & Pumps 2 01-26-2008 07:43 PM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
