Old 11-06-2016, 05:09 AM   #1
2004 31' Classic
Fairlee , Vermont
Hydro Furnace 65 Caravel
I'm helping my cousin restore/refurbish their 65 Caravel and I'm hoping someone can offer some suggestions on the furnace. The pilot light lights and the burner comes on but it puts out very little heat. The unit has no fan so I understand it's not going to heat like mine in my 04 Classic. I did blow out the burner area with high pressure air but didn't seem to make any difference on the heat output. I can see the flame and it looks like it is burning about as high as a stove top burner on a medium setting.
If we end up having to replace it what should we use for a unit? Thanks. Lee
nickoftime is offline   Reply With Quote
Old 11-06-2016, 05:13 AM   #2
Retired.
. , At Large
Welcome to the forum.
With such a small trailer, you really don't need a fan-forced furnace. If you don't like the original furnace (and I'd really hesitate to use it), you can get a small furnace, similar to that used in pop-up campers. If you want one that doesn't have a fan, you can look into a catalytic heater.
Old 11-06-2016, 06:29 AM   #3
1964 19' Globetrotter
1978 25' Tradewind
Linden , Michigan
Suggestions
Remove the guts, replace it with a Suburban LP Heater behind the original metal shield. Put a hinge on the metal shield, put a shelf in, and use the area above for storage.
Or, just buy an electric heater, gut the furnace, keep the metal shield, hinge it, and use the area behind for storage.
Regards,
StevieB
StevieB is offline   Reply With Quote
caravel
'65 Caravel Hydro Flame valve control unit teeraniti 1956 - 1965 Caravel 7 01-09-2016 08:59 AM
Atwood Furnace, Hydro Flame, Land Yacht Clipper masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 6 01-27-2012 10:45 PM
Hydro flame in Caravel TDOW Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-19-2010 12:44 PM
67 Caravel Hydro Flame furnace advice vonzellen Furnaces, Heaters, Fireplaces & Air Conditioning 0 02-15-2010 07:22 AM
Hydro Flame furnace blower quit working won't start nsteel Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-04-2010 03:27 PM
