Old 09-05-2019, 01:46 PM   #1
2019 25' International
Providence , Rhode Island
Question How to measure 11" WC with manometer?
So I've seen the warm fridge thread:
http://www.airforums.com/forums/f425...-up-80870.html
And he had 7" vs. 11" and it may have solved his issue.
So, got me thinking.
How do I actually measure this? I see this device:
https://www.amazon.com/Yellow-Jacket...gateway&sr=8-1
and I am wondering, does it just hook up to the LP port in the front and tell me there?
If it isn't registering 11" WC, I assume there is a way to adjust for 11"? Is that done right on the two way selector somewhere in the propane tank area?
This question is directed to a 2019 International Serenity, but I assume it matches other units also.
Can someone in the know please advise the best way to do this test, adjustment.....validation?
Chris
kittmaster is offline   Reply With Quote
Old 09-05-2019, 04:24 PM   #2
2020 Classic 33
Box Elder , South Dakota
If you can hook it up at the fridge. Remove the gas connection at the fridge and connect the manometer. May need a collection of various size fittings to make it work.
If you are not getting the correct reading, 11", the you adjust the silver regulator below the bottle selector switching gizmo. There should be an adjustment screw. See if you can download a manual for your specific model so you know which way to go.
Also before you make any changes if it is lower than 11" check all of the lines to make sure there are no kinks restricting flow.
I think I have the same unit and it works fine.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 09-05-2019, 04:47 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Not the reply you are looking for, but my trailer has a W.C. gauge in the gas line just before the fridge. I have had to adjust my regulator because of a warm fridge...IMO, all trailers need such gauge.
CRH is online now   Reply With Quote
Old 09-05-2019, 07:29 PM   #4
2016 16' Sport
Miami , Florida
You can use the LP port.
Adjusting the regulator depends on the model.
You can also build a meter in about 8 minutes for maybe 5 bucks.
Shiny16 is offline   Reply With Quote
Old 09-06-2019, 11:03 AM   #5
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Score one for the older models! Our 1996, 34'er also has the gauge at the refrig. Seems like AS wants to add more new bells and whistles than practicality......
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 09-06-2019, 01:58 PM   #6
2008 27' International FB
Hillsboro , Texas
How to measure WC
This is how I do mine with the same test equipment you have. I turn off the propane at the tank. Lift up stove top unplug one of the burners and connect your test equipment there. Go back, turn on propane and you should see 11 of WC on the gauge. Turn the propane back off. The gauge should slowly go down. It will not stay at 11 for long. If it does stay at 11 WC then you have a bad propane value. If it goes down quickly, then there is a leak somewhere.
grwalk is offline   Reply With Quote
Old 09-06-2019, 02:03 PM   #7
Thanks for all the feedback, you'd think this would be a standard install item so that people can check the health of their systems.
I'll review the threads and give them a look.
thank you for the feedback.
Chris
Manometer guru's crispyboy LP Gas, Piping, Tanks & Regulators 14 08-25-2016 08:51 PM
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
How to measure TT bjstewart1 Our Community 3 10-02-2002 09:28 PM
How to measure TT bjstewart1 Our Community 4 10-02-2002 05:41 PM
