11-02-2020, 03:32 PM
Falls Church
, Virginia
Help Removing Gas Regulator From My Main Gas Line
Hello Everyone. These forums have been a wealth of information to me over the years so I thought I would see if the community could help me with my problem.
I own a 2019 30' Flying Cloud Bunk with a gas regulator that wasn't working properly, so I decided to replace it. Despite many attempts, I was unable to loosen the bolt connecting the regulator to the main gas line to the trailer. As was recommended, I used one wrench to hold the gas regulator while using another wrench to turn the bolt. In my efforts, I managed to damage the old gas regulator, which isn't too problematic as it wasn't working anyway.
However, I now have the remnants of my old gas regulator still attached to the gas line, which I am unable to remove. I've tried using WD-40 to loosen the bolt to no avail.
Has anyone had this happen to them? Does anyone have any advice on how I can loosen the bolt that connects the gas regulator to the main gas line?
Thanks in advance everyone.
11-02-2020, 03:38 PM
2000 25' Safari
Denver
, North Carolina
I wish I could go out and confirm this but gas fittings are often counter to regular fittings. Not RIGHTY TIGHTY. Just a suggestion and I can take the hits if I'm wrong. I watched a group of mighty men try and remove a wheellugs on a truck wheel for over an hour, some truck wheels are threaded "backwards" for some reason I forget right now. It took an oldtimer to walk up and point that out...then sit back and smile.
11-02-2020, 06:40 PM
Falls Church
, Virginia
Thanks mbubbaca. Very helpful.
Can anyone confirm whether the thread on the bolt between the gas regulator and the main gas line is actually lefty tightly instead of the usual righty tighty?
11-02-2020, 07:01 PM
1993 34' Excella
York
, South Carolina
If they are indeed reversed threads, as gas lines typically are, the nut will have a small groove cut into each of the flats to designate it as reversed thread.
No groove, no reverse thread.
Pretty sure the threads on the regulator are not reversed.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
11-02-2020, 07:44 PM
2016 23' International
Long Beach
The gas line coming out of the regulator is normal tapered (clockwise—tight) thread.
Sometimes the pipe dope/sealer applied to the threads can cause the fittings to bind up.
You’ll need to give it more elbow grease and perhaps step up to 2 medium size pipe wrenches.
11-02-2020, 07:45 PM
2007 22' International CCD
Corona
When I last replaced pigtails and hose on my regulator this year they were all standard threads, not reversed. The old POL fittings with the brass nose were left hand threads and have the grooves.
11-02-2020, 08:01 PM
2019 30' Classic
Canfield
, Ohio
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
11-03-2020, 11:40 AM
1959 24' Tradewind
Twin Falls
, Idaho
Picture??
You keep saying 'Bolt'. Do you have a picture?
Is it actually a bolt, or is it:
1. Fitting coming out of the bottom of the regulator (which I think is a hose on that new of an Airstream)
2. Pig tail going into the regulator.
All of the fittings should screw on normal (righty tighty). I think the only thing that has reverse threads are the internal threads of the OPD fitting on the tanks themselves.
One more thought, it's completely disconnected from your tanks, Correct?
Have you ran the supply line clear, meaning you run your stove top until it burns all the gas out?
Maybe take a heat gun on a low setting to gently heat up the fitting then try to loosen the fitting.
Regards,
Tony
11-03-2020, 12:30 PM
Jim J
2014 30' Flying Cloud
Austin
Try heating with boiling water
I have had success in the past with pouring boiling water out of a teakettle over stuck threaded fittings, Wait a little but before you grab the fitting to loosen the connection so you do not burn your hands.
11-04-2020, 01:12 AM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Take the regulator and hose and put it in a vise. Then, with the correct size wrench turn it in the tighten (righty tight) just enough to disengage the back side of the threads. Now, try loosening the hose fitting. When it turns you will have both sides of the threads loose. The dissimilar metals have probably cause the fitting to seize. You might want to try soaking the fitting with liquid wrench to soften things up first.
guskmg
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Replacing main LPG line from regulator
Safari64 |
LP Gas, Piping, Tanks & Regulators |
4 |
09-26-2018 06:41 AM |
Help connecting the main gas line to a regulator 1965 Trade Wind
Rocker66 |
2 |
12-28-2016 10:58 PM |
68' Overlander: What line from regulator to main supply
AirstreamPDX |
2 |
09-12-2016 08:27 AM |
Main Gas Line Crimped
rbcarbo |
6 |
02-21-2015 04:35 PM |
main LP supply line from regulator
Byron71 |
6 |
11-15-2005 01:08 PM |
