Old 04-19-2023, 01:19 PM   #21
2008 27' Safari FB SE
2023 28' Pottery Barn
Delta , BC
Perhaps the tanks are taller?
bugman3 is offline   Reply With Quote
Old 04-19-2023, 02:08 PM   #22
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Originally Posted by bugman3 View Post
Attachment 430396
looks to me like you have much more room above the tanks. Note the top bar on mine is straight whereas others are curved down. I wonder if the cover is now shorter on mine.
Mine actually is curved up. No room above the tanks. Forty pound tanks.
10Smiles is offline   Reply With Quote
Old 04-19-2023, 06:28 PM   #23
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Attachment 430396
If you look at all the photos posted by people so far, it seems like a big difference in the setups is the tanks themselves. The aluminum tanks appear to have a taller collar on top without as many/as large holes in them, meaning that the hold-down bar goes on the top of the tank collar.
On the steel tanks there are large hand-holds built into the collars which can be used to place the hold-down bar.
Not sure which is 'better', or if one is better. But it would explain why people have such different setups. I'm sure that even between different brands of steel tanks there are differences, so it's easy to imagine that there are numerous combinations which will result in way different understandings of how the tank cover fits.
Maybe a better way to answer the question about tank cover size is for people to measure the covers instead of reporting how they fit. I believe that in recent years there have been two different tank cover lids in use - one taller than the other - to accommodate different types of tanks.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 03-08-2024, 02:59 PM   #24
Spartanfam's Avatar
2023 25' Flying Cloud
West Olive , Michigan
Airstream mounts the LP tanks too close to the power jack... and the LP tank cover doesn't set quite right, and bows in at the front near the jack. Poor design. Looks janky for a $100k travel trailer....
All things in time, all you'll ever need...
Spartanfam is offline   Reply With Quote
Old 03-09-2024, 07:48 AM   #25
Mollysdad's Avatar
Originally Posted by 100954 View Post
Attachment 430338
Attachment 430339
Attachment 430340
Finally figured out how to attach pictures (ipad). Again, this is a 2023 Fly Cloud 23FB Twin. The shelf I just made from scrape wood but it works good.
Yes, the cover on my 26U is just like those images.
I don't store anything because the tongue is already too heavy (1125#)
How has WBCCI changed? Mrs_RedSHED WBCCI Forum 88 02-20-2019 02:14 PM
What has changed on Airstreams over the years? Amarie Full-Timing 1 05-28-2015 07:28 PM
seems like airstream.com has changed carl2591 Off Topic Forum 27 05-16-2014 06:11 AM
How the forum has changed over the years. nickcrowhurst Off Topic Forum 28 10-31-2007 04:29 PM
My Status Has Changed SilverCabin Member Introductions 12 11-19-2006 08:14 PM
