RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-11-2021, 10:04 PM   #1
1972 27' Overlander
Columbus , Ohio
Gas sniffer beeps but no bubbles showing
Hi all, I just hooked up all the gas lines on my renovated 1972 overlander. I’m not getting any bubbles when I spray the connections, but when I use the gas detector I bought I’m getting a reading of detecting gas. Does anyone know if it’s normal to get some residual fumes at the connections that would make the gas sniffer go off or should there be absolutely zero readind? Thanks for any info!
action95 is offline   Reply With Quote
Old 01-11-2021, 11:24 PM   #2
2018 25' International
Slidell , Louisiana
There should be no gas detected. Does the detector go off randomly away from gas fittings?
If not there are likely small leaks. What are you using for the soap test? If you're not using a soap formulated for leaks it may not have enough surface tension.
Brian
Old 01-12-2021, 06:51 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Another of my dumb questions.
Is it a LP detector?
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Change is the new normal, if nothing changes, nothing is normal, everything changes, everything is normal.”
RLC
Tahawus
Old 01-12-2021, 07:22 AM   #4
1972 27' Overlander
Columbus , Ohio
Thank you for your replies. It is just dish soap, so that may be the problem. The detector had several gases listed that it will detect
Old 01-12-2021, 07:24 AM   #5
1972 27' Overlander
Columbus , Ohio
No, it was not going off randomly, and I have to keep it there for a few seconds before it will start going off. It seems to be coming out where the female fitting goes on to the gas pipe, not where the male and female connect, if that makes sense.
Old 01-12-2021, 08:30 AM   #6
Slidell , Louisiana
You can get the gas leak soap from amazon or at Home Depot, but you may want to remake the the suspected fitting. if they are pipe threads, you'll want teflon tape on it. If it is flare or knurled tubing, take it apart, clean the mating surface and inspect for damage, scratches, pitting or gouges. Good luck.
Brian
Old 01-12-2021, 08:52 AM   #7
Any day now....
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
And if it's NOT pipe threads, by no means should you use teflon tape.
2019 Flying Cloud 30FBB
Bunkhouse is sold...something more "classical" on order!
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is offline   Reply With Quote
Old 01-12-2021, 09:02 AM   #8
1986 25' Sovereign
Allegan , Michigan
The gas detectors can be very sensitive - which is a good thing. I have had good luck on threaded fittings using a blue colored pipe dope (Mega Block?); if you need the brand name let me know and I'll see if I can find the can in the shop. As far as teflon tape goes, I think they make a special yellow tape for gas. But I gave up on teflon, the blue pipe dope works better.
Good luck, Whit Nash
rwnash is offline   Reply With Quote
Old 01-12-2021, 10:10 AM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The detector is doing exactly what you bought it to do. It's spotting a leak that would be hard to find by other means. It just paid for it's self
Easy answer normally is to rebuild any joint(s) it does not seem to like. You can play with bubble stuff, but some leaks are hard to find that way.
When you pull this or that joint apart, check ( = examine visually ) both fittings. That may be hard to do, but if one is damaged / defective (it does happen ...) you will go around in a lot of circles rebuilding stuff. Same thing applies to the hose and pipe ends themselves. A crack there isn't going to be fixed by some more tape ....
Fun !!
Old 01-12-2021, 01:35 PM   #10
2021 27' Globetrotter
Tallahassee , FL
If you do use Teflon tape make sure it's rated for gas service and not water or liquids.
Kawboy01 is offline   Reply With Quote
Old 01-12-2021, 02:05 PM   #11
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Yellow Teflon tape, not the more common white stuff.
Greg
greghoro is offline   Reply With Quote
Old 01-12-2021, 10:21 PM   #12
Slidell , Louisiana
The Gas tape is just thicker so it seals a bit better. You can get the same effect if you quadruple wrap the white stuff if you're not able to find the yellow grade.
Brian
Old 01-12-2021, 10:37 PM   #13
2007 22' International CCD
Time out. That’s a shortcut to a propane leak that won’t seal up properly.
The white stuff, no matter how many wraps you put on will not seal propane. It’s just not dense enough. Propane molecules are just too small. I’ve tried that, and gave up. The big box stores carry yellow Teflon, as do most Ace hardware stores.
If you can’t find yellow Teflon, use a propane-rated pipe dope stick carefully. Don’t let it smear inside the fittings.
Old 01-13-2021, 06:19 AM   #14
My experience, I have used white to seal all threads, all applications, wrapping clockwise, tightening carefully and never had a failure.
The only difference is the thickness & $$$$.🤔
Disclaimer...I noe nothing.
Molly Ivins
RLC
Tahawus
Old 01-13-2021, 07:19 AM   #15
1972 27' Overlander
Columbus , Ohio
I appreciate all the responses here. Thanks for the help
Old 01-13-2021, 07:49 AM   #16
Slidell , Louisiana
I will say the yellow gas tape is also a bit more dense coming off the roll than the white tape because the white tape is stretched in the manufacturing process. Again if you overwrap it, the density will increase as it is compressed into the thread gaps. Sure the yellow stuff produces a more reliable seal so it is preferred if you have it.
Brian
Dometic BEEPS and Beeps and Beeps dlkershaw Electrical - Systems, Generators, Batteries & Solar 9 09-09-2018 08:54 AM
LPG Leak Detector Troubles/False Alarm beeps Tim_S LP Gas, Piping, Tanks & Regulators 26 11-21-2017 02:28 PM
Microwave Cycles and Beeps btuinstra Land Yacht/Legacy Motorhomes 1 09-20-2012 07:34 AM
Mystery Beeps?? Condoluminum General Interior Topics 4 02-15-2004 10:44 PM
How many Bubbles/ CA Bubbles? smallfry On The Road... 0 04-12-2003 09:40 PM
