Old 02-01-2024, 07:23 AM   #1
2023 25' Globetrotter
knoxville , Tennessee
Gas line to rear bumper
just got a ‘23 globetrotter 25fb and want to use our magma stove off the on-board propane. stove has a handy support that rests on the bumper rail in the back. problem is the lpg quick connect is in the front. there’s multiple lines (1/2” & 3/8”) underneath, but the ring supports they run through are riveted on. my question is what is the best way to secure the new gas line to the bottom of the trailer? i can tie into the distribution block easy enough.
kalel14 is offline   Reply With Quote
Old 02-13-2024, 12:17 PM   #2
i figured it out. just used ring mounts and self-tapping screws to the frame.
Old 02-13-2024, 01:57 PM   #3
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Welcome to Air Forums. Glad you figured out a solution to your question. When you have time, consider posting a picture or two of your project - it will be helpful to others.
See Ya Down the Road
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 02-14-2024, 12:27 PM   #4
gonna try to upload pics. basically- tied into the distributer with 3/8” lp gas line. needed 16’-ish to reach the rear bumper and ended up getting two 8’ sections male/female (https://a.co/d/3IAUkTw). used these crimp clamps (https://a.co/d/74bJteB) to secure underneath. before the axles, i used the already present pan screws & ran the line up & over the axels b/w the frame & out towards the rear. back there i used #8, 5/8” self-tapping screws to secure the clamps/line. left a bit of slack at the stabilizer (similar to the front) & secured to the rear frame with pre-assembled quick connect bracket from fleming (https://www.flemingsalesoem.com/product/quick-connect-female-lp-fitting-w-mounting-bracket-rv/). unrecoverable moments were spent searching for the separate parts for the bracket/connector/adapter when fleming had it already put together for cheaper…
final pic shows the mounting bracket for the magma grill, which i bolted to the frame (after pain-staking hole drilling…) because the mounting arm for the grill is offset and the shifting weight on it caused it to rock.
ID:	441030   Click image for larger version
ID:	441032   Click image for larger version
Old 02-15-2024, 05:02 AM   #5
remainder of pics
ID:	441054   Click image for larger version
ID:	441056   Click image for larger version
gas lines
Rear bumper cover latch doesn't line up correctly Dale T Bumpers & Bumper Storage 1 12-11-2023 08:26 AM
Help Removing Gas Regulator From My Main Gas Line airgoopy LP Gas, Piping, Tanks & Regulators 11 06-17-2022 07:52 AM
No gas from gas tank to generator intake line jraglow Mechanics Corner - Engines, Transmission & More... 15 08-12-2018 07:31 AM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Small crunch in rear bumper on 2003 LY (gas) spat61 Land Yacht/Legacy Motorhomes 4 11-06-2007 07:38 PM
