Old 06-21-2020, 07:12 PM   #1
1972 29' Ambassador
San Antonio , Texas
Question fully replacing gas lines, advice for ensuring it is leak proof
We picked up a 72 ambassador and have spent the last year fully gutting and modernizing. I'm currently running new copper for the gas lines and I'm struggling to leak-proof the system.
The entire system is 3/8" soft copper pipe (using 1/2" pex as a sheath on the underbelly) using flared fittings. I've hooked up a quick connect and a wc inch gauge to one end of my circuit so that I can charge the system using my air compressor (with the pressure dialed waaaay down).
I've been testing by charging up my system with 15 wc inch of pressure and then shutting the valve leading to the air compressor. Over the course of 15 minutes I'm losing about 1/4 to 1/2 of a wc inch. I've been bubble testing all of my fittings but haven't been able to pinpoint where the leak is. It's about 90 degrees outside, but the temperature isn't varying that much in 15 minutes -- is there a chance that could contribute to the drop that I'm seeing?
I'd imagine that any gas leak is a problem -- is my approach of charging using an air compressor providing a valid test? We don't have all of our appliances yet, so I don't have any way to do a proper load test. I haven't hooked up an actual propane tank to the system yet either.
Thank you in advance
satx_airstrm is offline   Reply With Quote
Old 06-21-2020, 07:40 PM   #2
2018 25' International
Slidell , Louisiana
the copper and rubber tubing, but not connected devices are good to 50 psi or more so first off don't mess with inches of water, go to 25-30 psi. Air is compressible so you'll need to let it stabilize for 30 min. Record the pressure as you go, if the changes are declining exponentially to a stable pressure, you have no leak, of the pressure just continues to decline you do have a leak. At 30 psi the soap test should easily find the leak. Good luck.
Brian
Old 06-21-2020, 07:56 PM   #3
1966 22' Safari
Fredericksburg , Texas
Sounds like a lot of fun. When we installed the copper in both trailers, we used L and, as you, using water hose or PEX on the belly pan for protection. We placed valves underneath at the final run to all items requiring LP. Also, I found it easier to use double flares versus single. Some think thatís an overkill, but didnít have any leaks. I think with the double flare you have a thicker roll of copper to conform to the flared fitting when tightened. Good luck
Bubba L is offline   Reply With Quote
Old 06-21-2020, 08:12 PM   #4
Images: 59
In addition to double flares (DOT requirement) it's also great to use forged flare nuts.
Old 06-22-2020, 11:44 AM   #5
1976 31' Excella 500
Chappell Hill , Texas
Valves could be leaking by? It's very possible. We always test to 50 with the appliances isolated by valves.
tbashin is offline   Reply With Quote
Old 06-22-2020, 11:44 AM   #6
2006 30' Classic
1966 20' Globetrotter
Dover , Delaware
To check your complete system wait until you have all of you appliances installed and you can do a leak down test with one of those gauges that hook up in series with you propane tank. That will tell the smallest of leaks. Just turn on the gas and bleed the system, the turn off the gas and see if the gauge goes down. It is not unusual for slight variations in the gauge because of temperature change.
I don’t know if 30 or 40 pounds of pressure would damage the regulators in each individual appliance.
I have used the method for years and do it at least once a year on my unit.
Good luck.
helwigc is offline   Reply With Quote
Old 06-22-2020, 02:58 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Do no apply more than 7 inches of water column (or 0.5 psi) pressure to gas generator regulators. You will blow them. That is why they are downstream of you low pressure regulator.
guskmg
Old 06-22-2020, 08:23 PM   #8
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
I did the initial test with air during the rebuild, but want a long term approach to being able to test. Since this isn't stationary like a house and subject to stress, I wanted to be able to test whenever it seemed appropriate. I got a leak detector for propane.
https://www.amprobe.com/product/gsd600/
The probe makes it easy to pinpoint the leak and is fairly small so we just carry it with us. Peace of mind
Can always use it at home. We're in the country and have propane.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 06-22-2020, 09:02 PM   #9
Slidell , Louisiana
Most RV appliances are tuned for/sized for 11 inches of water column on the low pressure supply side but have a fair cushion for overrating, still if appliances are attached, its best not go much higher than 11 inches and certainly not much over 1 psi. Isolated, the copper and rubber tubing is good for well over 50 psi.
To each their own, but in the petroleum industry, they add odorant for a reason. Your nose is your friend and the smell of the mercaptan is more than an adequate test for leaks.
Brian
Old 06-22-2020, 09:22 PM   #10
1972 29' Ambassador
San Antonio , Texas
This worked for me - thank you very much. Bumping the pressure up to 30 PSI gave me enough to work with to find the leaks that I had. After another day scooting around under the trailer I got it into a state where it's been holding at 32 PSI.
Old 06-23-2020, 10:04 AM   #11
Slidell , Louisiana
Very nice, Now as you add appliances you won't have to worry that any leak you encounter is in the supply lines. Let us know how the renovations are going. Should be a fantastic looking trailer when you're done!
Brian
Old 08-22-2020, 06:32 PM   #12
1975 Argosy 26
Corrales , New Mexico
Question for this thread: Where did you find the soft copper for gas. We went to Lowes and a specialty plumbing store today and neither had what we were looking for. We are replacing the water heater so needed new fittings, partial lines for that but can replace completely if needed. I'd also love to hear more about using pex as a protective "coat". Ours is an 75 Argosy and gas lines run mainly underneath the belly pan so are exposed. Thanks all!
rushhome6 is offline   Reply With Quote
Old 08-22-2020, 07:04 PM   #13
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
For safety, most of the gas lines are under the trailer. If there is a leak,, it will not fill up the trailer. When we were traveling to Alaska in 2018 it was suggested that we protect these line mostly because of the dirt road to Chicken. I used foam insulating covers with plastic ties and they are still on the lines today.
Richard
Old 08-22-2020, 11:53 PM   #14
Slidell , Louisiana
The rolled copper tubing is still used for Air Conditioning and gas lamps and such. Perhaps a specialty supply store or the mom and pop hardware stores. Airstream uses PEX to protect the copper only where road debris from the tire can hit it.
Brian
Old 08-23-2020, 12:02 AM   #15
guskmg's Avatar
Fort Worth , Texas
Most people pressure test for 20-30 min because it takes that long for temperature of the gas or air to stabilize and quit swrinking which lowers the pressure some what making it appear you have a small leak. BTW, I believe the larger Airstreams to day have larger tubing than 3/8". My classic has 5/8 copper tubing which was surprise for me. Next time I will measure it before assuming the nominal size.
guskmg
Replacing my gas lines. Air345Fly Classic Motorhomes 20 08-05-2020 07:01 PM
1963 Tappan Replacing Aluminum Gas Lines Help Mike Mohr Stoves, Ovens & Microwaves 9 04-14-2020 09:56 AM
Replacing Gas/Propane lines in a '73 Tradewind JenWilks LP Gas, Piping, Tanks & Regulators 0 01-13-2018 11:56 PM
replacing gas lines bennobel Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-08-2009 07:37 PM
Replacing Gas Lines? Frostyone LP Gas, Piping, Tanks & Regulators 2 05-14-2006 10:21 PM
