04-10-2018, 05:59 AM
2019 25' Flying Cloud
Fort Erie
, Ontario-Canada
Fitting from regulator to copper?
I'll get some pics up soon, but I'm looking for input on a fitting. I have a 77 LandYacht and purchased new tank lines and regulator to trailer lines from VTS. These are the thread on rubber connections. Mine were looking brittle.
Anyway there seems to be a fitting between the copper line and this new hose from the regulator that was not supplied. I attempted to remove it form the old line but it's in there really good and I figured should replace anyways.
Does anyone know what type of fitting this is? I'm going to visit Lowes this week and failing that CampingWorld or on-line sources.
Thanks for your help
Mike
Mike H
2019 25 Flying Cloud
2018 Basecamp (traded in)
'77 Land Yacht (sold)
04-10-2018, 06:36 AM
1993 21' Sovereign
Colfax
, North Carolina
I'll have to check the specific size, but I'm pretty sure it's a 1/8" PT-1/8" flare adapter.
04-10-2018, 07:50 AM
1974 27' Overlander
Baltimore
, Maryland
This connection from the rubber VTS line to the copper?  Mine was 1/2", and I think it's a flare on both sides, since I don't see any tape or pipe dope on the tank side of this coupling. You should be able to tell for sure by looking above the threads whether it's flared or flat.
04-11-2018, 07:02 AM
Fort Erie
, Ontario-Canada
I think mine looks a bit different. The pic shows the original line beside the VTS replacement and I知 guessing I need some type of male to male fitting to connect the two.
First time working with LP conections so my knowledge is limited.
If someone thinks Lowes or HD would stock these I値l drag both with me and pick up a piece. I hate ordering online when I知 not sure what it is I need.
Thanks all for your input!
04-11-2018, 07:37 AM
1976 31' Sovereign
Oswego
Both lowes & hd should have as these are standard fittings.
04-11-2018, 07:45 AM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
These are standard flair fittings
The dirty one appears to have a reducer on it? hard to tell without it being in my hands.
If you need to connect two males all you need is a flair coupling, if they are of diff size you will need a flair reducer coupling.
I think? they have flair fittings at HD.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
04-11-2018, 07:49 AM
1974 27' Overlander
Baltimore
, Maryland
1/2" brass flare union. Look again, you'll see yours is the same as mine.
https://www.homedepot.com/p/Everbilt...1279/300096849
Lowes will have it too. In the plumbing section, they're the brass fittings hanging up, individually bagged.
Note that flare fittings do not seal by the threads. They seal where the angled shoulders meet and compress together. Do not use pipe tape or dope on the threads. Get some 3 in 1 oil and put a drop or two on the male threads before assembling, then bolt together snugly. Get some propane line testing solution (should be in the plumbing aisle by the glue) to test this and all your other connections once it's assembled and pressurized.
04-11-2018, 08:54 AM
2017 22' Sport
NCR
, Ontario
when done, pressure the lines and place soapy water on each joint,
if you see bubbles, you have a leak, fix NOW
cheers
04-12-2018, 06:50 AM
Fort Erie
, Ontario-Canada
Thank you everyone for the help. I’ll hit homedepot this week and will definitely follow waninae39’s advice about leak testing!
Mike H
