First use of Interstate LP….smell gas…help please
I recently took delivery of a new 2022 Interstate 24GT. It was delivered from a FL dealer to us in TX, so no real pre-delivery inspection took place.
We’re new to RVs in general.
Today I fired up the LP for the first time to start breaking in the generator as per the manual. Before I started the generator, I lit both of the stove top burners and let them burn until the flame stopped flickering and then turned them off. This was for about 30 secs.
I wasn’t surprised to smell a little propane, but when I got out of the coach, I could smell it outside of the coach.
I let the air clear for about an hour and went back out and fired up the generator (possible a very stupid thing to do in retrospect). There was no further LP odor. I didn’t relight the stove burners or turn on the furnace.
We called the 24 tech support (coach-net), I explained the issue and he told me that I should not smell gas outside of the coach and needed to take it to the dealer.
We are supposed to be leaving tomorrow to travel from TX to PA after having sold our house here in TX, so we don’t have a lot of flexibility in timeline. Yes I know I should have checked this out when we first got it, but things with the move and sale of house got in the way.
We do not want to do anything unsafe, but I am wondering how worried I need to be about this and also if there is something easy for me to check on the LP lines.
I’m not much for crawling around underneath this thing, but could probably manage if it was to tighten a hose or a fitting. Anyone know the best place to look?
It seems the manual doesn’t include an LP gas layout, so short of crawling under it and following the gas lines, I’m not sure where to start.
Any help/ideas/suggestions will be greatly appreciated.
I also wondered if there could have been something related to the gas pressure release valve given it was the first time I’ve turned on any of the LP appliances and the swing in temps here today were pretty dramatic.
For those unfamiliar, the LPG tank on the Interstate is built in to the underside of the chassis (not removable).
Thanks in advance,
Kristin
