Old 08-01-2021, 12:10 PM   #1
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Dometic RM47 Fridge - Propane Issue
Hello all! It's been a long time...
Recently, in my 1976 Argosy, The dometic RM47 refrigerator no longer works on propane. Previously, it worked perfectly on both 110 v and propane. Now when I try to light it, It will ignite but the flame will only go to an orange yellow color and not the typical blue. Then it will eventually just burn out. I'm assuming there's some kind of oxygen to fuel ratio issue... Does anyone have any fixes for this? Something I should be looking for particularly?
I have the front end torn out so I am able to remove the refrigerator if needed...
Thanks for any help!
crabbey1 is offline   Reply With Quote
Old 08-01-2021, 03:24 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
General idea as I've never seen your model. Pics can help too.
The burner where the flames are, remove that burner tube and look for foreign objects, bugs, webs anything. Clean that burner tube out and try again.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 08-16-2021, 09:24 AM   #3
crabbey1's Avatar
1976 Argosy 22
Images: 33
I tried cleaning out the burner but apparently the igniter snapped. And manually lighting, it it still doesn't light correctly. The flames are coming out earlier in the tube than where it's supposed to...
Does anyone know where I can get a new burner assembly for this model?
I will add some photos...
Old 08-16-2021, 05:14 PM   #4
GCinSC2's Avatar
Sorry, no clue where to search for parts. Do you have this service manual? https://rvrefrigeratorrepair.com/wp-...ce-EarlyRM.pdf
On page 31 it has an illustrated parts list, page 33 and 55 show the burner. If flame is not coming out where it should I'd look for burner tube obstructions or obstructions in the chimney.
Broken parts, oops.
Pics might bring other ideas.
S/OS #001
Old 08-19-2021, 10:49 AM   #5
crabbey1's Avatar
1976 Argosy 22
Images: 33
Here is the view from outside.
It is a Dometic RM47 Fridge.
Old 08-19-2021, 04:39 PM   #6
crabbey1's Avatar
1976 Argosy 22
Images: 33
That manual is very helpful. Know that I know what I need, anyone have any idea of where to locate it?
Looks like I need a thermocouple and an ignitor. Possibly a new burner jet and burner pipe.
Chris
1976 22' Airstream Argosy
Dometic fridge fan running while fridge is off fclewis Electrical - Systems, Generators, Batteries & Solar 4 10-17-2018 08:30 PM
Dometic Fridge Issue. HELP!! oceanicdb General Repair Forum 12 08-15-2016 08:48 AM
Dometic Fridge issue vicn2000 Airstream Trailer Forums 1 05-02-2012 10:15 AM
Dometic propane re-light issue Boondocker Refrigerators 15 02-09-2011 11:47 PM
Dometic Fridge not lighting w/Propane zimode Refrigerators 9 09-21-2009 07:08 AM
