RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-17-2019, 02:00 PM   #1
2017 28' International
Domestic stove top spark
We have a 3 burner stove top. One of the burners has stopped igniting using the sparkler. It will light using a flame. It still shows a faint spark but not as strong as the other two burners which work. Is there a way to clean the spark pin ? Thanks.
Neen is offline   Reply With Quote
Old 04-17-2019, 02:01 PM   #2
Sorry, the title should have said “Dometic “. Darned auto complete!
Old 04-17-2019, 02:06 PM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
I had a problem with our middle burner no longer lighting, and it turned out to be the wire had come off on the back side of the sparker knob. It doesn't require any tools to get to it. First you have to twist the burners counter-clockwise so that you can lift them up and unplug that end of the wire, and set them out of the way. Then you just have to remove the top by lightly squeezing/twisting the brackets that hold it in place, and then you can slide the top backwards (it feels spring loaded) until it releases in the front and you can lift it off.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is online now   Reply With Quote
Old 04-17-2019, 06:45 PM   #4
z , Texas
Not my video,but did so this mod to our AS
https://youtu.be/Ew35fXJ2AyY
5150mike is offline   Reply With Quote
Old 04-18-2019, 10:30 AM   #5
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
DIDO with 5150mike replace with "Onlyfire 14441 Spark Generator BBQ Gas Grill Replacement for Char Broil,Huntington CharmGlow, BBQ Grillware GGPL-2100 and Others, 3 Outlet"AA" Battery Push Button Electronic Ignitor" found on Amazon - in Canada $16.00 best upgrade ever!!!!
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
No spark from stove burner pilot KerriO Stoves, Ovens & Microwaves 8 01-16-2012 11:37 PM
Atwood water heater -- light on, no gas or spark dre00 Water Heaters, Filters & Pumps 4 02-27-2009 10:51 AM
Electric Spark Arizona Guys Electrical - Systems, Generators, Batteries & Solar 2 03-09-2007 08:14 PM
1975 Argosy MH 454 proper spark plug gap? cejohnsonjr Mechanics Corner - Engines, Transmission & More... 2 04-21-2006 11:17 PM
Burning Spark Plug Wires geodude1958 Mechanics Corner - Engines, Transmission & More... 10 07-10-2005 08:58 PM
