Old 08-09-2024, 10:30 AM   #1
2024 25' Trade Wind
Bothell , Washington
Composite Propane Tanks
We have a 2024 Airstream Trade Wind. I’ve been considering new lighter weight composite Propane Tanks. https://www.vikingcylinders.com/product/22-pound-vapor/
While researching, I read on the online forum that U Haul would not fill composite tanks. That would cause a problem during our travels.
A couple of days ago, I noticed that U Haul is now selling the Viking Composite Propane tanks. Hmmmmm
I contacted U Haul corporate and received the following response.
U-Haul does fill the Viking Composite tank that you see online at the U-Haul store. We do not fill any other brand of composite tank.
Respectfully,
Scott Johnson
Propane Program Manager
Hope this helps anyone considering.
Chuck
charlesk is offline   Reply With Quote
Old 08-09-2024, 02:51 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Do compost tank save enough weight to make them worth it???
2019 Ford Expedition Platinum
Old 08-09-2024, 03:33 PM   #3
2024 25' Trade Wind
While there is no 30lb composite tank, there is a 22lb tank that weighs half of a 30lb steel tank. 12 lbs.
Technical Specifications
Specification 22 LB
Propane capacity 22 lbs
Propane volume at 60° F 5.24 gallons
Butane capacity 26 lbs
Water capacity 53 lbs
Weight 12 lbs
Height 22.5 inches (Perfect for replacing 30lb RV tanks)
Diameter 12 inches
Chuck & Yvonne
2024 Trade Wind
2024 Rivian R1T
Old 08-09-2024, 03:52 PM   #4
nelsonh's Avatar
2023 23' Flying Cloud
Carroll , Iowa
Composit vs steel comparison data
Coincidental timing on this topic....
FWIW I've been pondering the switch to the Viking tanks in the interest of tongue weight reduction, and in so doing ended up making a spreadsheet of the comparative specs and data between the 3 sized of Viking tanks vs the 2 common sizes of steel tanks, in order to help determine if the reduction in LP that would come with the reduction in weight would be a workable tradeoff.
I've done my best to make sure my numbers here are accurate (based on the Viking website and some careful Google fact checking), but I certainly don't guarantee there are no oversights within. Screenshot of my spreadsheet attached below, hopefully it will be legible and perhaps even useful to someone here.... (PS this was made merely for my personal reference and was never intended for public consumption...tank photos not quite to scale)
Name:	Screenshot 2024-08-09 at 5.05.04 PM.jpg
2023 Flying Cloud 23FBT ~ 2024 Ford F150 XLT PowerBoost 7.2 kw ~ 2010 Border Terrier
nelsonh is offline   Reply With Quote
Old 08-09-2024, 04:26 PM   #5
DKB_SATX's Avatar
Alamo Heights , Texas
Aluminum cylinders are close to the same weight as the composite ones without the problems with picky refillers and shorter lifecycle.
— David
Old 08-09-2024, 05:10 PM   #6
Portland , Oregon
nelsonh,
Thanks for that info.
You may want to include the all aluminum Worthington tanks to your comparison. Really nice tanks.
Name:	Screenshot 2024-08-09 at 4.05.38 PM.jpg
blacklab is offline   Reply With Quote
Old 08-09-2024, 08:13 PM   #7
2022 27' Globetrotter
DALLAS , TX
I looked hard at the composite tanks.
They are expensive
Recertification is problematic and in some areas it is impossible
I felt a decent percentage of weight reduction came via capacity reduction (less material needed for the smaller tank and less propane in the tank)
In the end, 30lb aluminum tanks were the right choice for me for tongue weight reduction. I chose Worthington tanks with the built-in tank level sensor. These sensors can be directly plugged into the analog sensor port on the victron cerbo GX, so you can track your propane tank level on the victron system.
foobar is offline   Reply With Quote
Old 08-10-2024, 04:58 PM   #8
nelsonh's Avatar
Carroll , Iowa
Originally Posted by blacklab View Post
nelsonh,
I think you might be right... the aluminum tanks didn't even cross my mind, mainly on account of me being new to this whole AS life. I'll for sure compare the Worthington tanks to the others, and I definitely like the idea of the built in gas level sensors mentioned by foobar above, that's pretty appealing .
Old 08-10-2024, 10:44 PM   #9
Portland , Oregon
I hope I'm wrong, because I will soon be in the market for a couple of Worthington aluminum tanks, but I'm not sure Worthington makes their vertical aluminum propane tanks with those built-in sensors anymore.
Cheers,
Bryan
Old 08-12-2024, 12:01 PM   #10
nelsonh's Avatar
Carroll , Iowa
Cheers,
Bryan
Appears you may be correct. Worthington's website isn't super detailed, but I don't see any reference to tanks with level sensors anywhere. I did find the 30# vertical tanks with sensors on Vintage Trailer Supply (link below)... but the version with sensor shows as "backordered". Oh, and they're $450 each.
https://www.vintagetrailersupply.com...-tank-vts-169/
Old 08-12-2024, 01:06 PM   #11
Portland , Oregon
Unfortunately, the Worthington aluminum tanks (including the ones without the sensors), have had big price increases in the past several years.
Cheers,
Old 08-14-2024, 04:48 PM   #12
Loco Airstreamer
shannon's Avatar
1970 23' Safari
Denton , Texas
I am not sure how long you go until "recertification?" But I do have two brand new Vikings on my 70 Safari 23 - and they came with tons of certification paperwork (in case you get jammed up somewhere). Feather lightweight ... now to get them filled and all my propane run throughout!! This road goes on forever.
shannon is offline   Reply With Quote
Old 08-15-2024, 07:44 AM   #13
nelsonh's Avatar
Carroll , Iowa
Which size of the Viking tanks did you go with? I'd be interested to hear your opinions and experience with them, including any issues getting them filled.
Old 08-15-2024, 09:50 AM   #14
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
The US is a bit of a mess when it comes to propane regulations because it is state based. And not even all states have a state bureau that regulates what is permitted and what is not when it comes to filling, qualification, and so forth. It's not totally the "wild west" out there; states often base whatever they do regulate on NFPA 58 (the most recent code book for LP produced by the non-governmental National Fire Protection Assn). However, when it comes to new innovations like the composite cylinders, matters can get kind of sticky and tangled across jurisdictions.
Lynn
ACI Big Red Number 21043
Viking Composite Propane Tanks RMNummi LP Gas, Piping, Tanks & Regulators 49 11-09-2023 06:21 AM
Composite LP tanks? Daquenzer LP Gas, Piping, Tanks & Regulators 4 07-09-2021 08:54 PM
17# Composite Propane Cylinders Airrogant LP Gas, Piping, Tanks & Regulators 15 11-23-2020 11:40 PM
Tanks, Tanks, Tanks PSU1981 Plumbing - Systems & Fixtures 8 09-02-2019 09:34 AM
composite LP tanks tarnished LP Gas, Piping, Tanks & Regulators 5 04-29-2012 11:19 AM
