RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-20-2018, 08:25 PM   #21
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you for the information. I have not read the regulation. I will print it and pass it on to my local guy.
David
WBCCI #8607
VAC Region 11
See my 1966 Trade Wind Renovation Documentation:
Knowledge Base Airstream Trailers
See my 1975 Overlander Improvement Journal:
See our 1976 Sovereign Renovation Project:
Old 05-20-2018, 08:32 PM   #22
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
David
WBCCI #8607
VAC Region 11
Old 05-21-2018, 08:50 AM   #23
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Originally Posted by A W Warn View Post
My opinion based on> (see the USDOT rules in the link above)
Whoever stamped those numbers into the cylinder actually created damage (dents in the wall of the tank) The numbers should have been stamped in the collar.
I noticed the same, but that’s my opinion. The PDF showed references IIRC.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 05-21-2018, 12:06 PM   #24
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by tadpoletim View Post
I discovered last year that my aluminum tanks from 2005 can not be recertified in Canada since they do not bear a Canada DOT code...
Me too. I had them certified and filled in Michigan and paid only for the propane. Next time we need a refill I'll take it to a local place just out of curiosity to see if they'll fill it here in Canada based on the US recertification.
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
Old 05-21-2018, 12:24 PM   #25
ShullsinUtah's Avatar
Draper , Utah
Our are due.
There's a place just up the road from where I work that does it.
ShullsinUtah is offline   Reply With Quote
Old 05-21-2018, 12:27 PM   #26
1995 30' Excella
Harper Woods , Michigan
hmm, i wonder if there is a uniform stipulation as to where the certification date should be stamped.
I don't know about aluminum tanks, but I've seen other steel gas cylinders that have been recertified many times - the oldest from the early 1920s - and they were stamped into to the top of the tank near the valve.
Bob Blarney is offline   Reply With Quote
Old 06-25-2018, 05:09 PM   #27
2005 30' Classic S/O
Kamloops , British Columbia
Recertifying US DOT Propane Tanks in Canada
This is an update to my post of a few weeks ago. I called a friend who lives near the BC-US border who spoke to his local propane supplier who told him that Transport Canada recently changed their regulations so that non Canadian certified propane tanks that meet US DOT standards can now be recertified and refilled in Canada. To verify this was correct I called a Transport Canada inspector of dangerous goods who confirmed that this was correct. So I then called my local propane supplier who had a few months ago declined to recertify my US DOT tank (he had done the other tank last year - presumably without thinking or checking) and told him what I had been told. even then I had to wait two weeks while he got written confirmation from Transport Canada. When I went in to collect my recertified and refilled tank he was gushing with enthusiasm for the quality and durability of the Worthington made aluminium tank with pressure gauge, rather ironic in view of the previous rejection and willingness to condemn to the scrap yard!
The tank now bears the recertification date and identifier of the recertifying dealer and is good for another 10 years.
To quote from the TC regulations:
CSA*B340 specifies the selection and use requirements for cylinder and tube specifications that are authorised for use in Canada by Subsection 5.10(2) of the TDG Regulations. This includes cylinders and tubes that have been in use in Canada for many years and that belong to one of the following groups of specifications:
* Cylinders and tubes that have been manufactured in accordance with CSA*B339. These cylinders and tubes are commonly referred to as “TC specification” cylinders and tubes because the prefix marked before the specification designation is “TC”.
* Cylinders and tubes that have been manufactured in accordance with the U.S. Department of Transportation’s Hazardous Materials Regulations entitled Title*49 of the Code of Federal Regulations of the United States (49*CFR). These cylinders and tubes are commonly referred to as “DOT specification” cylinders and tubes because the prefix marked before the specification designation is “DOT”.
Ref: Transport Canada
http://www.tc.gc.ca/eng/tdg/moc-cyli...-473.html#what
tadpoletim is offline   Reply With Quote
Title Date Different From Mfg Date skitique Title, VIN & Registration 11 04-25-2015 09:04 AM
Date of Manufacture of Propane Tanks Msmoto LP Gas, Piping, Tanks & Regulators 14 01-31-2015 05:44 AM
Manufacture model/date timeline? tiniree Our Community 1 04-22-2003 03:40 PM
A date that will live in infamy....December 7 BobbyW Our Community 0 12-07-2002 09:38 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 10:54 AM
