Old 03-06-2020, 07:47 AM   #1
ChuckZ's Avatar
1966 26' Overlander
2012 28' Flying Cloud
Waukesha , Wisconsin
Can/should I lubricate my switchover dial?
This morning I went to change over my lp tanks from the empty to the full and the dial got to the straight up position and hung up. Didn't want to continue on to the new tank position. With some encouragement (I pushed the bejesus out of the thing) it did make it far enough to use the full tank. Is it possible that this just needs a tad of lubrication or is it probably shot? I'm reluctant to start spraying lub on something I shouldn't.
ChuckZ is offline   Reply With Quote
Old 03-06-2020, 08:08 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Original? Replace.
Ours started to feel funky two seasons ago, replaced with a Marshall unit.
Together with new supply lines.
Tahawus
Love for the Adirondacks
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
RLC
Old 03-06-2020, 08:44 AM   #3
2018 25' International
Slidell , Louisiana
Replace is the low risk way to go as Bob indicates, but sure you can lubricate it with some "dry" lube or some water displacing lubricant/corrosion protectant like WD40 or Corrosion X. If it doesn't "loosen" up after lubing under the knob to the stem then it is hanging up inside and you will have to replace it or disassemble it... I would do that but maybe that is not a task for the weak at heart.
Ill let you use your judgement.
Note to Bob: Your stuff is always so nice looking and organized. I don't dare post pictures of my stuff. I couldn't compete!
Brian
Old 03-06-2020, 01:50 PM   #4
_________________
Thanks Brian,
But it doesn't apply everywhere...🥴
Tahawus
RLC
Old 03-06-2020, 02:12 PM   #5
Mitch
jmitchell's Avatar
2020 30' Classic
Granite Bay , California
Originally Posted by ROBERT CROSS View Post
Original? Replace.
Nice upgrade. I was just observing that the factory hoses rub the cover and lp assembly at multiple locations. Is the Marshall switching valve considered the benchmark of reliability, I have not researched it?
Mitch
2020 Classic 30RQB
2013 2500HD Dmax: 6in lift; GEN-Y Traveler (torsion flex) hitch; Load Range F (3-Ply sides); 1-ton leafs; Hellwig sway bar; Firestone Ride-Rt RED; Bilstein 5160s
Registered Professional Engineer, CA
jmitchell is offline   Reply With Quote
Old 03-06-2020, 02:56 PM   #6
It was a bit more expensive than the AS original, but the quality shows, it also has higher flow rate. Seems to make things easier to start up after storage.👍
Tahawus
RLC
Lubricate or don't lubricate WD hitch DrPlay Hitches, Couplers & Balls 6 09-25-2008 08:57 PM
Lubricate Steps willyd Steps 3 06-18-2008 04:30 PM
theVAP Episode 47: Meet RJ Dial Safari Tim Airstream "In the News" 5 06-23-2007 10:19 PM
lubricate the bearings frederic.c01 Axles 38 08-12-2006 12:45 AM
