RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-09-2018, 12:09 PM   #1
1985 34' Excella
Sandusky , Ohio
Black water tank
Newbie here! We are camped for summer on riverfront site. Grey water empties at site. Black water tank is emptied by honey bucket service every other week.
We are at AS about 3-4 days per week. In between (hot weather of summer) upon return and flushing toilet there is strong sewer odor. Should be invest in portable tank for emptying into as we leave (then honey bucket could empty that one biweekly). ??? I have been using Unique RV Digest It in toilet frequently and always tank is emptied.
Should we leave bathroom fan on? Leave Fantastic Fan (w/rain sensor) on??
Thanks for any suggestions.
pauliesg is offline   Reply With Quote
Old 04-09-2018, 12:59 PM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Don't have bathroom fan on when flushing toilet as it will draw up the tank odours.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 04-09-2018, 05:48 PM   #3
Byron Center , Michigan
Black water tank
I wonder if the seal on your toilet valve or the seal at the floor has gone bad. Does the bowl hold water? Have you tried leaving some water in the bowl while you’re gone? That will leak down if the seal is bad. Then I wonder about the toilet base and how good that seal is. Also wondering if your sink trap/shower trap is holding water. Sometimes the gray tank can smell bad, too, and in some trailers, the bath sink is plumbed to the black tank. Make sure there’s a few cups of water poured down the drains, especially if you don’t use them (sounds like you do, but just in case).
YippieKiYa is offline   Reply With Quote
Old 04-12-2018, 06:09 PM   #4
1985 34' Excella
Sandusky , Ohio
Black water tank
Thanks for these tips. Will check the seals and follow up all your suggestions. We will be taking Spring delivery of AS back to campground in 10days. Reply to follow......
Black tank only for gray and black water??? mmollema Waste Systems, Tanks & Totes 9 02-01-2017 05:36 PM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 08:53 AM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 06:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-02-2011 12:51 AM
