RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-26-2019, 10:25 PM   #21
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Originally Posted by learn2dive View Post
We have been full time for almost 2 years and find that using 1-tank until empty and switching tanks and getting empty filled works well, we were not using the furnace to often and primarily electric sites with 10 day boondocking occasionaly. So when the propane supply shut off we would close valve and open other valve, replacing empty tank that week or so and repeating the process as needed.
Same here, I guess I just wanted to get fancy.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 05-27-2019, 03:45 AM   #22
2015 28' Land Yacht
Chapel Hill , North Carolina
I recently exchanged emails with Mopeka regarding functionality with aluminum and composite tanks.
Bottom line: it will work with aluminum tanks but you’ll have to figure out how to attach it. It will NOT work with composite tanks.
Matt
HappyHapgood is offline   Reply With Quote
Old 05-27-2019, 06:16 AM   #23
Re-Pete's Avatar
1992 29' Excella
Matt
Same here, and I also spoke by phone with a guy named Chris who may also be the same Chris who answered my emails although he made no mention of it. In my case he did think it would work with composite tanks as well as aluminum, but establishing and maintaining a good surface contact was the problem with the non ferrous tanks, and according to Chris, Mopeka has no accessory at this point to make that possible.
Based on your conversation they seem to have changed their stance on composite tanks. At any rate, it's kind of a mute point without a way to maintain a decent and consistent contact. Using this gadget to read my tanks via my smart phone was a nice thing to think about, but not important enough for me to give up my aluminum tanks.
Pete
Virginia Beach, VA
Old 06-06-2019, 02:18 PM   #24
2018 30' Flying Cloud
Boulder , Colorado
Mopeka monitor problem
Based on the comments on this thread, we ordered the Mopeka tank monitor and the base accessory. When we installed it on one tank, it read 23% full. As soon as we put the metal cover over the tanks, it read 77% full. When I call Mopeka support, they said yes, that tank cover would disrupt the Bluetooth connection and screw up the reading. If that’s really the case, I’m wondering why others don’t seem to experience this?
Bkeller is offline   Reply With Quote
Old 06-07-2019, 08:36 AM   #25
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Spring , Texas
See my earlier test - do not seem very accurate to me.
Glenn
PSU1981 is offline   Reply With Quote
Old 06-08-2019, 06:00 AM   #26
AirstreamCSH's Avatar
2016 25' Flying Cloud
Huntington , New York
We have them on two trailer and I really can’t recommend others buy them. When they work they work fine but you can’t really trust them. Then they go through a period where both of them work only on the phone Bluetooth App and not the display. The key to longevity is to apply a dab of dielectric grease to the sensor Every Time you take them off to fill the tanks. Change the battery yearly and check expect to get 2 years from them before the sensors fail completely.
AirstreamCSH is offline   Reply With Quote
Old 02-03-2021, 08:16 PM   #27
2019 27' International
Western NC , North Carolina
Someone recently here installed these and based on that comment which I can’t find I decided to give the. A shot as well given every time a tank went empty was at 3am when it was 30 degrees. Brr...
Anyway ordered 2 and installed them on standard tanks. Interface was simple and they quickly told me one tank was down to 3% and the other was full. ��. Filled the empty one and I can now easily check before a cold night.
I’ll see how they perform over time but initial impression is ��
2019 International Serenity 27 FBQ “TC Escape”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
LPG monitor hickory LP Gas, Piping, Tanks & Regulators 3 08-08-2016 10:08 PM
LPG Sensor - Which to use with SeeLevel 2 System? trekerboy Electrical - Systems, Generators, Batteries & Solar 5 01-02-2015 10:58 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 03:20 PM
Tank monitor system on the fritz mhilley Fresh Water Systems 7 11-27-2011 09:57 AM
Upgrade to a new system monitor? GoNomad Electrical - Systems, Generators, Batteries & Solar 7 10-27-2006 08:02 AM
