Old 02-20-2020, 09:40 AM   #1
1965 17' Caravel
Edisto Island , South Carolina
battery operated lp detector
I would rather not try to run any more wires in my 1965 Caravel but would like to have an lp detector. Any suggestions would be appreciated.
zlarryb is offline   Reply With Quote
Old 02-20-2020, 10:21 AM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
A quick look at pplmotorhomes.com part site (my go-to supplier of parts) lists only 12v wired models.
Maybe an rv requirement they be hard-wired? Someone will let us know if that's true.
rowiebowie is offline   Reply With Quote
Old 02-21-2020, 09:52 AM   #3
rowiebowie's Avatar
2012 Avenue Coach
My hardwired Propane detector for my AS motorhome is on the battery disconnect, so is off when switch is off. Since the propane tank solenoid is electric and will only operate when the battery switch is on, I guess they figure "no electricity, no propane". It may be different for a trailer, however.
Best Battery operated CO and Smoke Detector RBolton Batteries, Univolts, Converters & Inverters 7 03-03-2020 04:18 AM
Vacuum operated step pushes man over the ledge Dean Rawson Classic Motorhomes 5 08-13-2010 11:07 PM
Electric Operated Window Blinds willyd Upholstery, Blinds, Walls & Interior Finishes 2 09-12-2008 05:02 PM
Electrically operated awning? Kistler Awnings 2 09-04-2006 04:02 PM
can the univolt be operated without batterys connected 0557 Batteries, Univolts, Converters & Inverters 5 08-01-2004 08:48 AM
