Old 12-08-2019, 06:44 AM   #1
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Baby Q and the LP port
was planning on using the LP port to supply propane to our Weber Baby Q, but researching I have learned that the pressure from the LP port is too low to adequately supply the needs of the Baby Q. I don't want to sacrifice the ability to run the grill on bottled gas, but would sure like the option of the LP port, so has anyone discovered a solution?
Thank you
rbs is offline   Reply With Quote
Old 12-08-2019, 07:24 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Convert a Q Kit
Thank you
I use the Torjik Weber Q conversion kit. It replaces the regulator on the Q to use with quick connect fittings. It is easy to take those fittings off and replace with the regulator if you need to use the small bottles.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 12-08-2019, 07:29 AM   #3
2018 25' International
Slidell , Louisiana
You could take a pin vice and small drill bits and drill out the gas orifice about one or two sizes larger. Then test it to see if it has sufficient heat output on the LPG port, while still having decent range and not too hot with the bottle and regulator. It's a bit iffy fiddling with the orifices but I do it with nearly every grill I have ever bought so I can use nature gas at home rather than propane. The results are not as good as something properly engineered but it works.
Old 12-08-2019, 01:39 PM   #4
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
I removed the high-to-low pressure regulator from the grill and added two fitting to end with a 3/8" flare fitting. From that fitting, you can add a 10' propane hose with a quick disconnect fitting to connect to the Airstream low-pressure port. My Weber Q can reach 450-500 degrees connected to the Airstream low pressure port. http://www.airforums.com/forums/f42/...ml#post2186916
You can buy a standard gas grill replacement regulator and hose so you can run the Weber Q from a large propane bottle. https://www.amazon.com/2106-Propane-...8P9H6X6VXCJ30H
Then you can buy this adapter to use with the standard gas grill replacement hose and still connect to 1 pound disposable propane bottles. https://www.amazon.com/Disposable-Th...K93ESY4B8CMEZ7
2018 GT27Q, 73 nights 12,177 miles, 600W Solar - 110kWh, PD4655L, 6V Batteries, Blue Ox, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, Propride, 400W Solar - 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(O+5200)
AirMiles is offline   Reply With Quote
Old 12-11-2019, 04:52 PM   #5
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
thanks
great info, headed to lowes in the morning
Old 12-13-2019, 05:48 AM   #6
JJTX's Avatar
2018 19' Flying Cloud
South of Austin , Texas
Have you actually tried it first ?
I run my Blackstone on the gas port and it works fine.........
JJTX is offline   Reply With Quote
Old 12-23-2019, 12:00 PM   #7
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Suwanee , Georgia
Thank you
Not sure what researching source you found, but our grill works fine using a 12 foot hose connected to the trailer's LP port.
I just ran it on high for about a half hour to burn the accumulated grease off the grate and it got up to 550 deg. In normal usage it gets plenty hot on the lowest setting to grill anything I've put on it. Normally I run it with the lid down, which helps in retaining the heat. Seems to cook about as quickly as the large Weber grill I use at home.
Erik & Carol
Suwanee, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
LP Fill Port and Generator Muffler Relocation wachuko Sprinter and B-van Forum 31 07-01-2018 06:34 PM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 08:57 AM
Outside propane port and grill bennu36 Sprinter and B-van Forum 9 09-01-2013 09:16 AM
Split rims and baby moons aluminitus Wheels, Hubs & Bearings 4 04-03-2012 07:45 PM
A bambi, a boxer, and A BABY! panub Our Community 10 04-12-2004 02:10 PM
