Old 08-04-2021, 07:27 PM   #1
2017 27' Flying Cloud
Celina , TX
Atwood water heater question
2017 27FB with Atwood water heater. First boondocking trip and find that the igniter isnít reliable. I managed to light the water heater with a match, but most of the time I can hear the igniter clicking and smell gas - but no flame. The water heater has worked great using shore power.
Before I start replacing parts, I wanted to ask if anyone has diagnosed a similar problem and how you solved it.
Texasbr549 is offline   Reply With Quote
Old 08-04-2021, 09:58 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Time to clean the fuel / air tube. Remove it by informing 2 or 3 screws and use a wire brush to clean the inside. 90% of the time this clears things up.
wulfraat is offline   Reply With Quote
Old 08-05-2021, 05:07 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
You can also adjust the gap in the ignitor. Wrong gap can cause problems. Lots of videos on this on YouTube.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 08-07-2021, 05:58 PM   #4
Celina , TX
Thanks, folks.
While cleaning the fuel air tube, I found the igniter gap was set at 1/16” instead of 1/8”. Simple adjustment. Simple solution.
Old 08-07-2021, 08:14 PM   #5
wulfraat's Avatar
Originally Posted by Texasbr549;
Thanks, folks.
While cleaning the fuel air tube, I found the igniter gap was set at 1/16Ē instead of 1/8Ē. Simple adjustment. Simple solution.
Boom. Back on the road again with hot water nice.
Sediment in Water blocking Atwood Water heater zita Fresh Water Systems 0 05-14-2021 07:07 PM
How does a Atwood XT water heater make more hot water? Dremel Water Heaters, Filters & Pumps 9 10-27-2018 12:24 AM
Atwood Water Heater Question star kitty Water Heaters, Filters & Pumps 9 03-25-2017 08:02 PM
Atwood water heater uwe Water Heaters, Filters & Pumps 5 10-03-2009 01:58 AM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
