Old 04-13-2021, 08:57 AM   #1
HighPlainsDrifters
2019 27' Globetrotter
Casper , Wyoming
Atwood-Dometic Furnace Not Delivering Heat
We have a 2019 Globetrotter with an Atwood furnace, Dometic thermostat. When the thermostat is set, for example, at a desired interior temperature of 65 degrees the furnace will deliver heat fine (raise the interior temp to 65....shut off when reached......come back on to raise to 65 again, etc.) for a day or two. Then, it will simply stop delivering heat. The interior temperature will drop on a cold night to mid 40's.
I need to shut down the entire system, reboot, set the furnace to 65....it works until it doesn't. Obviously this is a pain.
I have replace the sail switch. I have replaced the motherboard. The limit switch is fine.
QUESTION: has anyone experienced this issue? If so, how was it resolved?
My marriage, especially on a chilly Wyoming evening, is depending on your assistance.
This is not hyperbole.
Thank you.
2Highplains is offline   Reply With Quote
Old 06-08-2021, 08:08 PM   #2
2020 16' Caravel
Shoreline , Washington
Thank you.
yes and am still experiencing it- it is super frustrating. I posted this thread a while back: https://www.airforums.com/forums/f28...ry-218788.html
If you've discovered a fix since you posted this question, I'd be glad to hear it!
bparrish is offline   Reply With Quote
Yamaha EF2000is v2 not delivering power to Go Power panel/ trailer polar911 Generators & Solar Power 15 08-23-2020 02:17 PM
Atwood furnace blower works but no heat cgseanp Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-20-2018 08:49 AM
70 Ambassador, Fresh tank isn't delivering full amount of filled water albert Fresh Water Systems 6 01-02-2018 05:09 PM
Airstream delivering Happiness geekgrrrl Airstream "In the News" 4 02-19-2015 08:48 PM
New Marshall Regulator not delivering the gas like the old Fisher Lothlorian LP Gas, Piping, Tanks & Regulators 5 08-16-2009 05:20 PM
