RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 07-18-2020, 07:00 PM   #1
Bonney Lake , Arkansas
As tank gauges
Hi all. I'm new to this, so I hope this isn't a dumb question;
Is there such a thing as a gauge that tells you how much propane you have left in your tanks? One that attaches to the tanks themselves?
We bought a new 2020 Basecamp X, (after seeing it, should have waited for the Basecamp X 20').
Thanks.
Hofbcx is offline   Reply With Quote
Old 07-18-2020, 07:15 PM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
First of all, greetings and welcome to the forum.
Yes here is one method to determine how much propane is in your tank. Here is a link to the the website (https://mopeka.com/). I have this system and it works well.
Best wishes!
Old 07-18-2020, 07:59 PM   #3
rd tighe's Avatar
2007 25' International CCD FB
South , Texas
Images: 12
We have done the old trick of poor warm water over the tank and feel it. where it is cold is the level. Tryed and True. But the other thing sounds very interesting.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Old 07-19-2020, 07:51 AM   #4
2020 28' Flying Cloud
Jax Beach , Florida
I use the Mopeka and it works well for me. I also got the halo rings for the bottom of the tanks to provide the clearance needed and to not have the aluminum spacers that come with the sensors beating up the tray the tanks sit on. The phone app works well, but the 2-pack sensor I bought also had the battery operated guage that I mounted inside and works well.
gzvette61 is offline   Reply With Quote
Old 07-19-2020, 09:21 AM   #5
Mollysdad's Avatar
👍 Works!
Old 12-06-2020, 10:25 AM   #6
2018 22' Sport
Healdsburg , California
Do you see rapid discharge of the 2032 batteries on you Mopeka? Mine don't last a month. I've had Mopeka about two years. At first the 2032 batteries lasted several months. Now the new batteries need to be changed monthly or sooner? Do Mopeka's wear out? Do I need to buy new ones? That could get $$. I'd appreciate advice.
Cheers, Roy
lilboomer is offline   Reply With Quote
Old 12-06-2020, 10:43 AM   #7
stevejones's Avatar
2019 27' Globetrotter
Traveling to , Arizona
I use the Mopeka Tankcheck as well. Also have the halo rings. Works well for me. Once a year or so I have to replace the batteries. The app tells you when they are low. When you replace the batteries you have to resync the sensors. Not a big deal.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
stevejones is offline   Reply With Quote
Old 01-27-2021, 09:44 AM   #8
2020 23' Flying Cloud
Fort Worth , Texas
Newbie here. . .Looking at buying the Mopeka set-up. Went to their website (link below) which has the Mopeka (1) Check Standard LPG Sensor (which seems to be what everyone is using), and they also have the (2) Mopeka Pro Check Sensor-Aluminum (or Steel) LPG Cylinders. Has anyone used the second one or know what the difference is.
https://mopeka.com/shop/
They also have a wifi bridge for extra $$$. Has anyone had experience with that?
Thanks!
missaviatrix is offline   Reply With Quote
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 09:19 PM
Tank monitors, level sensors and/or gauges. BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 16 09-24-2010 01:09 PM
dual tank gauges ALANSD LP Gas, Piping, Tanks & Regulators 9 01-02-2007 08:30 PM
Tank Gauges, Repairing of Bedford General Motorhome Topics 3 07-24-2006 04:20 PM
Tank Gauges tschat Waste Systems, Tanks & Totes 5 07-15-2006 01:56 PM
