02-14-2011, 07:54 AM
1981 27' Excella II
mays landing
, South Jersey
I may be wrong, but I believe these tanks have to be horizontal. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
02-14-2011, 11:48 AM
Wise Elder
2010 30' Classic
South of the river
Forklift cylinders are set up for liquid withdrawal and will not work properly for trailer use. The 1 1/4" acme valve threads won't fit the 1 5/16" on the regulator on your trailer, by design.
02-14-2011, 12:44 PM
1964 26' Overlander
Richmond
, Virginia
That's what I was looking for. I don't know who owns Vintage trailer supply, but by the time I'm done accumulating the order, I expect his kids to send me a thank you note when they finish college.
02-14-2011, 01:14 PM
1965 22' Safari
Vassar
, Michigan
Not sure why you say this. The forklift tank on amazon was listed at 149.95 and the proper tank on VTS is $157.00. All alum. tanks are expensive. You could go with much cheaper steel tanks and cover them.
Tim
TAC MI 14
Everyday is a Saturday
02-14-2011, 02:16 PM
1997 25' Safari
1973 25' Tradewind
Greenville
, South Carolina
Most Fork lift tank come with two ports. One for liquid and the other for vapor. If it has both ports, just remove the liquid valve and plug it. Install a Vapor valve, the new tri handle, and now you have a tank that can be used vertically.
Rick
02-14-2011, 02:39 PM
1964 26' Overlander
Richmond
, Virginia
I'm not begrudging VTS. Love those guys and they provide a great service. I just wanted to save money where I can. Amazon is not charging me shipping on top of a slightly cheaper price. I wanted someone to tell me why VTS was the right way to go. I'd rather go with the right solution, and I wanted aluminum tanks.
02-14-2011, 03:24 PM
Ottawa
, ON
Or, there's a 40-pounder. Keeps you away from the popane dealer longer!
Courage is being scared to death, but saddling up anyway. ...John Wayne...........................
02-14-2011, 04:08 PM
2021 27' Globetrotter
Saint Louis
, Missouri
The forklift tank has a gauge which is a $70 option at VTS. It would be great to know if they did work.
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
02-14-2011, 04:43 PM
1964 26' Overlander
Richmond
, Virginia
That was something I was wondering as well.
02-14-2011, 09:45 PM
Airstream - Other
Bosque Farms
, New Mexico
Yeah, if you look at various tanks, you'll find top-output (meaning vapor) and bottom-output (meaning liquid). Forklift tanks are bottom-output. Bad news for RVs, bbqs, and the like.
Lynn
ACI Big Red Number 21043
02-15-2011, 09:54 AM
Wise Elder
2010 30' Classic
South of the river
Forklift tanks are meant to be used horizontally. If installed vertically, the float gauge will not work.
They are a commodity product manufactured and sold in much larger quantities than the relatively specialized vertical aluminum tanks we use.
02-16-2011, 05:41 PM
More than one rivet loose
Los Alamos
, New Mexico
they work. I have had them for five years in both 30 and 40 lb tanks.
Michelle TAC MT-0
Sarah, Snowball
02-17-2011, 05:49 AM
1964 26' Overlander
Richmond
, Virginia
you use these horizontal tanks? Do you just ignore the float gauge?
02-17-2011, 06:56 AM
Putnam
, Connecticut
You bought a vintage trailer. Do it right or do it twice. There is nothing wrong with steel tanks. You can paint them silver, which is alot less work than polishing the al ones. You need to understand that the process is endless, the dollars are many, and the time three times what you would expect if you want a fully undated shiney trailer. I'ld suggest you use it for a season before doing much to it. You may find it is OK to have steel tank like stuff.
They have the best price I could find. Get the fuel gauge on at least one of the tanks.
02-17-2011, 07:06 AM
Naples
Just a quick rant on always searching for the 'best price'.
A company like VTS is a very valuable resource in this community. Send your business to the large retailers who might have the item a bit cheaper and watch the small, service oriented companies Like VTS, Inland RV and others whither away and disappear. Then you will have NOTHING except your cheaper price to thank!
And BTW, keep shopping at Wal*Mart while you're at it and support those good folks in the corporate board rooms who gleefully send US jobs to China and other offshore locations so they can increase their bonuses and the bottom line of their corporations while helping to decimate the US middle and working class.
Rant over!
lewster
02-17-2011, 09:49 AM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
Import Cheap
Lew:
I hear you!
Dave
02-17-2011, 10:19 AM
1972 25' Tradewind
Falling Rock
, West Virginia
You can check the liquid level of any propane tank by pouring very hot water over the outside of the tank. A condensation line will appear, to give you a approximate level of liquid propane.
02-17-2011, 01:34 PM
1964 26' Overlander
Richmond
, Virginia
Rant over!
Rant away, I just sent VTS over $300 and plan to send a lot more. For something that is very standard, and that may be taking up a lot of room in their inventory, and be very heavy to ship, it was one of the few things I was looking elsewhere for. In hindsight, I probably should have kept the steel tanks and painted them. Certainly would have been much cheaper. I was kind of looking at resale value when considering the Aluminum. The old steel ones had just been sitting in a garage for a while. I could probably go back and get them, but it was an even split for the long term on how to handle those. And the savings I got from the aluminum tanks probably would have gone right back to VTS in the form of something or other since we are nuts about the Overlander.
I completely agree with the rant though. We buy our milk from a small family owned (meaning the teenage boys milk the cow) farm, and I do my best to support small family owned or regional businesses.
