Old 11-23-2021, 08:36 AM   #1
2019 22' Sport
Centreville , Virginia
30lb please tanks
I was wondering if anyone has swapped out their 20lb LP tanks with 30lb tanks. I have a 2019 22FB Sport and looks like it is doable but the tie down bracket require modifications. Curious before I try…Bobby
rpkoz is offline   Reply With Quote
Old 11-23-2021, 09:51 AM   #2
1976 31' Sovereign
Oswego , Illinois
Thumbs up
Easy to go larger, IMO all you will need is longer rod.
Old 11-23-2021, 10:38 AM   #3
Mount'n Man's Avatar
Cedarcreek , Missouri
I put aluminum 30's on a 63 Avion. Had to install a longer ½" threaded rod for the hold downs and a short section of copper gas line to reach the regulator (this trailer has all copper gas lines with compression fittings). Ended up putting the aluminum 30's on our Airstream and going back to aluminum 20's on the Avion as it is a show rally trailer, but the process was simple.
Mount'n Man is offline   Reply With Quote
Want to Trade my 30lb Propane Tanks for your 20lb Tanks WEBOPS LP Gas, Piping, Tanks & Regulators 43 01-23-2021 11:38 AM
30lb Worthington tanks ChuckZ 1965 - 1969 Overlander 7 01-14-2017 07:21 PM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 01:37 PM
30lb aluminum propane tanks diggerdude Airstream Classifieds 1 02-16-2014 07:51 AM
