Old 11-14-2020, 01:43 PM   #1
Air Mobile
2005 25' International CCD
Newport News , Virginia
25.4 LB propane tank to old to refill
Hello All,
I have a 2005 25' International that has two 25.4 lb propane tanks. I went to get them refilled and found out they are too old, dated 05/04, I'm guessing May 2004. They are stamped "must be requalified within 12 years of manufactured date." Four Questions:
1) Is it better to just buy new tanks or get them requalified?
2) If requalified, anyone know where in Newport News, Virginia?
3) If buy replacements, anyone know where in Newport News, Virginia?
3) I don't see many mentions of 25.4 LB propane tanks online, I wonder if 30 LB tanks would fit in my existing case? There's no more width available in the silver sleeve, but could go a 3-4 inches taller.
Many thanks!
Tim
ID:	383239   Click image for larger version
Tim_S is offline   Reply With Quote
Old 11-14-2020, 02:21 PM   #2
1976 Argosy 26
Henderson , Kentucky
Images: 21
I just use smaller tanks, and easier to manage, and just wondering is there a need for tanks instead of those you can just exchange? And carry an extra tank if need. Be Safe.
Be Safe. Mitch
Ky76Argosy is offline   Reply With Quote
Old 11-14-2020, 03:10 PM   #3
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Your 30 lb cylinder doesn't look to be in bad shape, but an inspector will look for more than superficial rust and any bends in the collars, cracks in the welds. I'd suggest calling around to the various LP dealers (not just fillers, but full service shops) to ask what a recertification costs in your area. Some have a large fee; some have a nominal free; some will do it for free if you also have the cylinder filled there.
Your cylinder is a 30 lb, not a 25. Here's a little video to explain:
Lynn
ACI Big Red Number 21043
Old 11-14-2020, 03:24 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
The printing on your tank that says TW 25.4 is the "Tare" weight. That's what the tank weighs empty. I believe what you have there is a "thirty-pound" tank.
According to a web page I found, a 30 pound tank is 24 inches tall.
https://www.propane101.com/consumerpropanecylinders.htm
SSquared is offline   Reply With Quote
Old 11-14-2020, 03:46 PM   #5
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Shop around 30lb tanks are available lots of places
sheriff1 is offline   Reply With Quote
Old 11-14-2020, 03:55 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
20lb tanks are easily exchangeable at many places like Home Depot. 3o lb , not so much. if you can live with 2 20lb tanks, exchange them. Otherwise buy new. IMHO.
2019 Ford Expedition Platinum
Old 11-14-2020, 04:52 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my trailer is the same year as yours; I got my tanks recertified. Note: recertification in the USA is not good in Canada.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 11-14-2020, 05:46 PM   #8
Air Mobile
Thanks everyone! Good info
Old 11-14-2020, 05:54 PM   #9
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
Its best to get a new tank IMHO.
also, when the tank is getting close to 10 years, go to a std.n that does swaps. ensure that the swapped tank is newer then yours. then you never run into this issue.
ALSO, each state/Province has different age limits on propane tanks
also, i never saw a 25 lb tank, the std is 20 lb , 30 lb and higher
waninae39 is offline   Reply With Quote
Old 11-14-2020, 05:58 PM   #10
2019 27' International
Western NC , North Carolina
Just so you know when you do a tank exchange at xxx store those tanks are not filled to capacity in general and you pay a premium for the exchange.
Also a 30lb tank has 2ish more gallons of propane which can make a difference when running the furnace.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 11-14-2020, 06:05 PM   #11
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Just a note for ROBERTSUNRUS, the 30 lb aluminum tanks on my trailer could not be recertified in Canada because of the age of the tanks. If they are dated of mfg prior to 1993 they can be recertified in Canada. This is for aluminum tanks only to my knowledge.This is a rule that I was not aware of. I had to take my tanks back to US to get recertified. This certification is approved for Canada. I have never had problems getting them refilled, nor have I ever heard of a problem having tanks filled in Canada if the certification date is current. If the tanks do not have the new style excss flow valves in them they will not refill.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 11-15-2020, 09:11 AM   #12
1960 24' Tradewind
dudley , Massachusetts
propane tanks
I have 2.... 30lb. aluminum tanks with OPD and gauges. The tanks cost me $15.00 each to have certified after the 12 year expiration. Visually checked and a sticker installed valid for only 5 years. If I had steel tanks I would scrap and buy new ones.
bobstock is offline   Reply With Quote
Old 11-15-2020, 09:40 AM   #13
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
How do you know this? Propane is always temperature corrected.
Silvr_Bullet is online now   Reply With Quote
Old 11-15-2020, 09:58 AM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Recertification is simple..
Old 11-15-2020, 10:10 AM   #15
2017 16' Sport
N/A , N/A
Someone on the forum suggested that certification of propane tanks are not standard in the US, that’s false.
Old 11-15-2020, 10:12 AM   #16
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Get them recertified and save yourself a bunch of money....
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 11-15-2020, 10:59 AM   #17
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
For me, I like the convenience of the 20 lb tanks, they can be exchanged everywhere, or refilled, when I want to take the time, to have it done
bibbs is offline   Reply With Quote
Old 11-15-2020, 11:00 AM   #18
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
here in Canada where I am on the west coast its cheaper to recertify 30lb tanks ....20lbs unfortunately are just better to go to costco and buy new. Trade a tank is expensive propane here compared refilling at costco.
rucos is offline   Reply With Quote
Old 11-15-2020, 11:17 AM   #19
Google is your friend.
Capacity of a 20 lb tank is 4.5 Gallons
30 lb tank is 7 gallons
40 lb tank is 9.4 gallons
Old 11-15-2020, 11:25 AM   #20
2017 16' Sport
N/A , N/A
Weigh your tank after it’s filled subtract that weight of the empty tank from the filled tank,difference is the weight of the propane, as stated when tank is filled it’s not to 100% of the volume of the tank, so weight will vary.
Newbie question re. refill of propane tank jpfromla LP Gas, Piping, Tanks & Regulators 12 08-19-2014 08:08 PM
Propane Refill on I-65 Alabama? Ridgerunner3 On The Road... 4 01-01-2012 08:49 PM
Old LP tanks vs. new Aluminum, refill? cuyeda LP Gas, Piping, Tanks & Regulators 4 12-04-2006 03:08 PM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
Propane refill question Kistler LP Gas, Piping, Tanks & Regulators 2 10-19-2003 07:39 PM
