RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-23-2020, 08:58 PM   #41
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
Originally Posted by Silvr_Bullet View Post
How do you know this? Propane is always temperature corrected.
The swap tanks are not filled manually so they leave a bigger safety margin to ensure plenty of airspace
Less contents and higher price so only for rich or time-poor people
Tony Lee is offline   Reply With Quote
Old 11-24-2020, 02:00 PM   #42
Silvr_Bullet's Avatar
42į 2' 27" N / 74į 7' 6" W , US
25.4 LB propane tank to old to refill
Safety is more important than shopping to squeeze an extra ounce or two of propane in your propane tank, the people here that speak to 80% capacity are right on.
Nothing wrong with swapping tanks, they are professionally maintained and thatís certainly worth a few ounces of propane more or less to me.
Silvr_Bullet is offline   Reply With Quote
Old 11-24-2020, 03:27 PM   #43
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
i would get the tanks from Costco. Those sold by Costco has build in gauge so you would know how much propane you have in the tanks.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 11-24-2020, 06:40 PM   #44
heslinhotel's Avatar
1989 29' Excella
1999 25' Safari
Youngsville , North Carolina
Tim S. Don't waste time or effort trying to re-certify...If you look at your 3 pic you can see the tanks do not have the "triangle" Valve. This means no OPD valve in tanks. they can't pass inspection unless you have OPD valves installed. But being steel tanks just buy new steel 30lb tanks or if budget allows go with Worthington Aluminum. Stay safe
Steve
heslinhotel is offline   Reply With Quote
Old 11-24-2020, 07:25 PM   #45
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
To my knowledge, Costco only sells 20 lb tanks, not 30.
sheriff1 is online now   Reply With Quote
Old 11-25-2020, 03:55 AM   #46
Air Mobile
2005 25' International CCD
Newport News , Virginia
Costco?
Thanks for suggestion. I did get them recertified, cost $15 at local full service gas company, they filled also. Do have a question about Costco since I'll replace with new next time. I checked online at Costco and there doesn't appear to be any 30lb lp tanks for sale, any chance they no longer sell the tanks? Costco did have 100lb tanks, but no 30lb.
Tim_S is offline   Reply With Quote
Old 11-25-2020, 05:15 AM   #47
Waukesha , Wisconsin
Did you ask the place that did the re-certification about getting new tanks next time around? They can probably get you exactly what you need and likely in a better quality than Costco. There are different levels of quality in all things sold, including propane tanks.
Propane tanks can be configured in an almost limitless number of ways, and you'll get exactly what you need working with a propane dealer who will set them up for you to fit your application. Even little things, like having the gauges & valves pointing the way you need them can make a huge difference.
More important to me in a situation like this is having a relationship with the local dealer. Not just because it supports them, but it supports you too. When something in your propane system goes awry, having an established relationship with them makes it much more likely that they'll go the extra mile for you to find that odd widget you need to get things made right.
richard5933 is offline   Reply With Quote
Old 11-26-2020, 12:19 AM   #48
2021 20' Caravel
Littleton , Colorado
I saw 30 # tanks online at Costco but then they vanished! Walmart sells Flame King 30 # tanks. A pair (two) goes for $110 delivered. Now that I've said that watch them sell out.
Blind Wille is offline   Reply With Quote
Old 11-27-2020, 03:02 PM   #49
Halford1's Avatar
guess the online services ran out of 30# but some Costco warehouse still sell them in obscured areas.
Newbie question re. refill of propane tank jpfromla LP Gas, Piping, Tanks & Regulators 12 08-19-2014 09:08 PM
Propane Refill on I-65 Alabama? Ridgerunner3 On The Road... 4 01-01-2012 09:49 PM
Old LP tanks vs. new Aluminum, refill? cuyeda LP Gas, Piping, Tanks & Regulators 4 12-04-2006 04:08 PM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-02-2003 12:08 AM
Propane refill question Kistler LP Gas, Piping, Tanks & Regulators 2 10-19-2003 08:39 PM
