Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2002 - 2005 International
Old 10-26-2005, 09:22 AM   #1
nangoff's Avatar
2004 28' International CCD
Franklin , Tennessee
LED Replacement for Halogen Cabin Lights
Has anyone come up with a LED replacement for the halogen cabin lights on the CCD's?
The halogens pull too much power.
I'm thinking there is, or soon will be, a g4 based led to insert into the socket the 10 watt halogen now occupies.....or there might be a complete lamp assembly to insert in the cabin cutouts.
Any help would be appreciated.
Gerry Goffinet
CCD 28, 2004
goffinet@comcast.net
nangoff is offline   Reply With Quote
Old 10-26-2005, 12:45 PM   #2
Westfalia's Avatar
Some Place with a German Name , Texas
Images: 35
Send a message via AIM to Westfalia
I've already got you covered, complete with pictures:
http://www.airforums.com/forum...-halogens.html
Westfalia is offline   Reply With Quote
Old 10-26-2005, 09:17 PM   #3
nangoff's Avatar
What do you think about this product?
Certainly looks powerful enough, do you think it will fit in the lamps?
http://www.ultraleds.co.uk/default.p...e0473d34043030
Gerry
Old 01-11-2008, 10:26 PM   #4
nangoff's Avatar
I did buy some of these lights, and I also replaced the factory supplied 10 watt bulbs with 5 watt ones. The light of the LEDs I'd describe as slightly less than a 5 watter which is less that a 10 watter. If I put the light output of a 10 watt halogen at a 10, I'd put the light output of a 5 watt halogen at a 7 and an LED assembly at a 5. Gerry
Old 01-12-2008, 09:20 AM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Try this link:
http://www.airforums.com/forums/f447...ens-17392.html
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-13-2008, 03:18 PM   #6
nangoff's Avatar
You can pretty typically get halogen bulb replacements (G4 bases) with LED arrays now on e-bay for about $15 (less in quantity) on e-bay.
eBay Motors: G4 White 14-LED Light Bulb Sailboat Boat Halogen Cars (item 190181704065 end time Feb-05-08 08:53:55 PST)
Has anybody tried some of these units from this vendor?
Gerry
Old 01-13-2008, 05:09 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I tried the LED replacements, and here is what I found:
Pro: cool running, low energy consumption, rugged for travel, small size.
Con: light color is terrible. Light output lower than the halogens. OK perhaps for accent lighting inside the CCD roof lockers, but unpleasant light color for task lighting. I took them out and re-installed the 10W halogen lamps. The aura returned..
Keep in mind that in the old days the 4 bulbs in a 70's trailer's roof fixture were up to 84 watts. 4 of the halogen floods make much better light at only 40 watts. Replacing those 4 halogen lamps with 5W units reduces this to 20 watts. Hardly a large draw on a healthy batttery, even during a few days of boondocking. That's about .2A.
I'd be more worried about the current draw of a furnace, water pump or 12V powered fan. Lamps are only needed for alimited time each day, anyways.
Uwe
www.area63productions.com
Old 01-13-2008, 06:18 PM   #8
2005 22' Interstate
Afton , Virginia
Uwe, I don't understand your last paragraph. I'm not trying to sharpshoot you, but if you have a 12 volt battery, 20 Watts would be .6 Amperes, wouldn't it?
regards
herrgirdner is offline   Reply With Quote
Old 01-13-2008, 06:22 PM   #9
2005 22' Interstate
Afton , Virginia
Correction
In my last post, I left off a "1". Read 1.67 A vice .6A. Sorry
Old 01-13-2008, 07:05 PM   #10
Naples , Florida
Hey Gang,
Imtra Marine makes/sells a direct replacement LED light that will fit perfectly into the G-4 halogen fixtures of the newer Airstreams. I have replaced ALL of my halogens with these.They have a slightly lower visual output, but I find the light level from these most acceptable.
Be sure to order the 'warm white' style, as this quality of light is virtually identical to the 10w halogen bulbs found in the AS. The 'cool white' is very blue and harsh!!
lewster
Old 01-13-2008, 07:36 PM   #11
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
http://www.airforums.com/forums/elec...-halogens.html
That URL doesn't work for me. Looks like the parent forum was renamed/relocated. This one does:
Maurice
Old 01-13-2008, 07:59 PM   #12
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
You're right, of course. I meant to write 2A, instead of .2A, while 1.67 is much closer to the formula.
Uwe
Old 01-13-2008, 09:28 PM   #13
nangoff's Avatar
I have yet to find any definitive lumens output of any of these LED arrays compared to classic halogen of 5 or 10 watts. Has anybody got a definitive lumen output of the LEDs?
Also, is the comparison of lumens between light sources linear or exponential? Example, is a 10 lumen light source twice as bright as a 5 lumen source or is it 4 times as bright?
Thanks, Gerry
Old 03-03-2009, 01:25 PM   #14
wppii's Avatar
East Nicolaus , California
Images: 33
I have replaced the dinig area lights with these
G4 LED lamp Specifications
Minor decrease in intensity, didn't have warm white when I got them but I like the power savings. I have the 6 bulb model, no problem with polarity in the socket
The Lovin' Oven is an 04 28' International CCD.
It follows where the F150 Supercrew leads.
"The only time to say "No" is when they ask if you've had enough"
wppii is offline   Reply With Quote
Old 05-08-2009, 12:22 PM   #15
silverbacksurfer's Avatar
2005 25' International CCD
Glendale , California
G4 base led replacement light bulbs 21 led
I found a site in China. The prices were very low compared to some other sites. Does anyone has an opinion on these? http://www.ledlightbulb.net/store/in...=2_49&products
They are a manufacture and will ship.
silverbacksurfer is offline   Reply With Quote
Old 05-08-2009, 12:29 PM   #16
Ottawa , ON
Link is no good...
Old 05-08-2009, 12:34 PM   #17
try this link
G4 Bi-Pin LED Replacement Light Bulbs, 21 LEDs, Warm white, 12V [G4-21LED-WW-12V] - $4.40 : LED Light Bulbs, Shop Online
Old 05-08-2009, 09:22 PM   #18
wppii's Avatar
Images: 33
I see these folks have added warm white and higher lumen (up to 111) bulbs than what were available when I got them.
Super Bright LEDs - MR16 and MR11 LED Bulbs
Be sure to scroll down the page to the G4 bulbs. I have had great experiences with their availability and delivery.
Old 05-10-2009, 08:44 PM   #19
nangoff's Avatar
This is one of the designs I purchased that failed. Gerry
Old 10-27-2014, 10:56 AM   #20
2014 update to this older thread on LED upgrades in vehicles originally fitted with halogens -
Selection and price both continue to evolve significantly. We replaced our halogens with a non-Airstream LED option because the intensity of the aftermarket product appeared to be better than what we had seen while touring new Airstream Interstates on dealer lots. Not only was there no decrease in intensity (a plague among first generation LEDs), the new LED pucks were brighter than the halogens. And yes, we used "warm white" as folks recommended here. Some of the blue-ish LEDs are really harsh.
The only complexity in using the generic product in the retrofit was that the pins needed a slight trim to fit the Airstream ceiling sockets. I have described that process with a bunch of photographs here (non-commercial, non-monetized blog link):
THE INTERSTATE BLOG: INTERSTATE LIGHTS, PART 1: HALOGEN TO LED IN THE CEILING
Alison and Lawrence
League City TX
THE INTERSTATE BLOG
2004 international
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
replacement tail lights for '69 Airstream bgow 1965 - 1969 Overlander 0 08-06-2002 10:03 PM
